[mapserver-users] OSM data rendering using Mapserver
Stephen Woodbridge
woodbri at swoodbridge.com
Thu Oct 29 20:42:01 EDT 2009
Ali_ wrote:
> Hi Stephen,
> Thanks for your response. I am grateful to you. Cygwin worked.
> I am getting this error
> loadLabel(): Unknown identifier. Parsing error near (MAXSCALEDENOM):(line
> 48)
> Is that something to do with the Mapserver versions?
Yes this sounds like you are on a very old version of mapserver. You
need to be on at least Mapserver 5.4.2 to use that mapfile.
What version are you using?
/path/to/mapserv.exe -v
Should tell you.
-Steve
> Ali.
> Stephen Woodbridge wrote:
>> Ali_ wrote:
>>> Hi,
>>> I am new to MapServer and wanted to render OSM data through that. I
>>> followed
>>> the tutorial
>>> http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
>>> but unfortunately I am unable to run it at the final stage. I am on the
>>> last
>>> step where I use 'make' command to compile osm.map file as an output but
>>> something seems wrong. I am getting 3 syntax errors in makefile. Now I am
>>> using Borland C++ compiler make utility. Before that I tried with TC
>>> compiler make utility. I was getting 5 syntax errors before but now its
>>> only
>>> 3. So I have some points in my mind which if you could clarify.
>> cpp is the GNU C preprocessor, you might have better luck if you install
>> cygwin on Windows.
>>> 1) The other map files such as landuse, buildings and highways have not
>>> MAP
>>> keyword at the start of each file. Though I tried with this but still
>>> couldn't get it working.
>> The map file is broken into logical pieces and uses lots of variables
>> that get resolved and replaces by the cpp. You can not use them as they
>> are. When cpp runs all the pieces get assembled into the usable mapfile.
>>> 2) The osm_line and osm_road table have not been assigned the primary key
>>> while conversion using osm2pgsql and where we query in the map file we
>>> use
>>> USING UNIQUE osm_id which may be incompatible and may be make is unable
>>> to
>>> give the result.
>> This probably will not impact mapserver running unless you are guerying
>> the features.
>>> 3) The first line in the makefile CPP=cpp tells about the compiler we are
>>> using. Could you tell me which exactly is the compiler I should use.
>> This is the GNU C preprocessor.
>>> I shall be grateful if I could get some comments from you. Thanking you
>>> in
>>> anticipation.
>>> Cheers,
>>> Ali
>> Hope this helps,
>> -Steve W
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
