[mapserver-users] Help with NQuery error (CGI)
Paul james
pauljame at gmail.com
Fri Oct 30 07:33:51 EDT 2009
Hey Steve...
Yes I had...
QUERYMAP
COLOR 255 0 0
SIZE -1 -1
STATUS ON
STYLE hilite
END
With Status OFF I got that :
Content-type: text/html
Using MSSQL2008
Paul
On Thu, Oct 29, 2009 at 6:13 PM, Steve Lime <Steve.Lime at dnr.state.mn.us>wrote:
> Do you have a querymap object configured with status on? I would guess
> so in order to see that
> error. What happens if you set STATUS OFF in the querymap?
> >>> On 10/29/2009 at 7:57 AM, in message
> <33fad6880910290557m71ee3fdatd470590e3256f175 at mail.gmail.com>, Paul
> james
> <pauljame at gmail.com> wrote:
> > Hello guys...
> > Ím got this error when trying to execute a Nquery :
> http://localhost/cgi-bin-54/mapserv.exe?map=Map.map&mode=nquery&LAYERS=TEST&mapex
> t=-58.358076171875+-11.42570625+-57.193525390625+-10.37101875&imgext=-58.3580761718
> 75+-11.42570625+-57.193525390625+-10.37101875&map_size=1221+762&imgxy=1221+762&imgb
> > ox=0+0+1221+762
> > msDrawMap(): Image handling error. Failed to draw layer named
> 'TEST'.
> > But, If I execute the same url with "mode=map", the image is
> generated
> > fine... What this error means?
> > TEST Layer
> > LAYER
> > NAME TEST
> > GROUP "TE"
> > TYPE polygon
> > STATUS ON
> > CONNECTIONTYPE PLUGIN
> > PLUGIN "msplugin_mssql2008.dll"
> > CONNECTION "server=X;Integrated
> Security=false;database=X;uid=X;pwd=X"
> > DATA "the_geom from viw USING UNIQUE oid USING SRID=0"
> > CLASS
> > TEMPLATE "template.html"
> > NAME "X"
> > STYLE
> > OUTLINECOLOR 150 150 150
> > WIDTH 1
> > END
> > END
> > END
> > Thanks
> > Paul
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20091030/9ecf9f1b/attachment-0001.html
