[mapserver-users] Maps based on external data
Yewondwossen Assefa
yassefa at dmsolutions.ca
Wed Sep 23 17:19:20 EDT 2009
Hi There,
maybe using OGR join to achieve that could be a solution. Check the
following post:
http://lists.osgeo.org/pipermail/mapserver-users/2004-November/002149.html
On a MapServer layer you can do something like:
LAYER
CONNECTIONTYPE OGR
CONNECTION "/test/my_shape_file.shp"
DATA "SELECT ..."
END
regards,
Varun saraf wrote:
> Hi,
> I am using mapserver to generate map overlays for google (using
> tiles). I was wondering if there is a way in which I can color code
> the map based on external data (data not available in the dbf file). I
> was able to join the external data and display to the user when a
> click event happened but could not figure out a way in which mapserver
> can color code using expressions and classes. Is the only way to this
> is combining the external data with the existing dbf file?
> Thanks,
> Varun
> mapserver-users at lists.osgeo.org
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
