[mapserver-users] LABEL_NO_CLIP=ON not working for point type
feature layers
=?GB2312?B?y9G6/NPSytY=?=
teeca at sohu.com
Wed Sep 23 10:38:28 EDT 2009
Hi all.
recently I try to output my map into tiled images, so far is O.K,
Polyline Feature layer duplicate labels can be fixed using PROCESSING
"LABEL_NO_CLIP=ON", but now I encounter point feature layer's labels
problem: When I get my tile images output, the label will be clipped out
at tile image's edge. The directive PROCESSING "LABEL_NO_CLIP=ON" is not
working for point feature layers ,can anybody give some suggestions?
the appearance of my clipped label is in the attachment.You can see the
gray text(polyline feature label) is properly splitted on the two
images, while red text(point feature label) is clipped.
Snippet from my mapfile
NAME "POI_01_CityDistName_P"
TYPE point
STATUS DEFAULT
OPACITY 100
SIZEUNITS pixels
LABELITEM "poiname"
LABELCACHE on
POSTLABELCACHE FALSE
TRANSFORM true
CLASS
NAME "Untitled class"
LABEL
ANGLE auto
FONT "C_HEI"
ENCODING "GB18030"
TYPE truetype
PRIORITY 1
SIZE 13
MAXSIZE 256
MINSIZE 4
COLOR 248 67 52
OUTLINECOLOR 255 251 240
BACKGROUNDSHADOWSIZE 1 1
POSITION uc
ANTIALIAS FALSE
FORCE FALSE
PARTIALS TRUE
END
regards,
teeca
Name: clipped point label.gif
Type: image/gif
Desc: not available
Url : http://lists.osgeo.org/pipermail/mapserver-users/attachments/20090923/18865357/clippedpointlabel-0001.gif
