[mapserver-users] Problems with PostGIS connection pooling
Ludwig Kniprath
ludwig at kni-online.de
Wed Apr 7 10:33:12 EDT 2010
Hello all,
I use mapserver 5.6.1 and php_mapscript (ms4w_3.0_beta10) on Apache and
PHP 5.3.2 (CGI).
The spatial-data (OpenStreetMap) is stored in PostGIS.
The map-creation ist called by a php-script, which himself connects to a
postgres database for administrative purposes.
In the map-File the PostGIS-Layers are defined with a different
connection then the calling php-script, that seems to be the problem.
Although the Layer in the map-file is defined with
CONNECTION "host=localhost dbname=osm user=max password=mustermann
port=5432"
the logfile shows, that mapserver uses the connection-parameters from
the calling php-script instead of the mapfile-parameters:
---snip---
[Wed Apr 07 15:53:48 2010].609000 msPostGISLayerOpen called: way from
(select way,osm_id ,landuse, name from planet_osm_polygon where landuse
is not null) as foo using unique osm_id using srid=4326
[Wed Apr 07 15:53:48 2010].609000 msPostGISLayerOpen: No connection in
pool, creating a fresh one.
[Wed Apr 07 15:53:48 2010].687000
msConnPoolRegister(landuse_layer1,user='kniprath' password='*******'
dbname='wver_ims' host='127.0.0.1' port='5432',02BDFD18)
[Wed Apr 07 15:53:48 2010].687000 msPostGISLayerFreeItemInfo called.
[Wed Apr 07 15:53:48 2010].687000 msPostGISLayerGetItems called.
[Wed Apr 07 15:53:48 2010].687000 msPostGISParseData called.
[Wed Apr 07 15:53:48 2010].687000 msPostGISParseData:
unique_column=osm_id, srid=4326, geom_column_name=way,
table_name=(select way,osm_id ,landuse, name from planet_osm_polygon
where landuse is not null) as foo
[Wed Apr 07 15:53:48 2010].687000 msPostGISLayerGetItems executing SQL:
select * from (select way,osm_id ,landuse, name from planet_osm_polygon
where landuse is not null) as foo where false limit 0
[Wed Apr 07 15:53:48 2010].703000 msPostGISLayerGetItems(): Query error.
Error (FEHLER: Relation »planet_osm_polygon« existiert nicht
LINE 1: ...ect * from (select way,osm_id ,landuse, name from planet_osm...
) executing SQL: select * from (select way,osm_id ,landuse, name from
planet_osm_polygon where landuse is not null) as foo where false limit 0
---snap---
These wrong connection-parameters cause the error, because in the
queried database "wver_ims" the osm-tables don't exist.
Question:
Why doesn't mapserver connect to postgres with the
mapfile-connection-parameters?
Thanks in advance!
Ludwig
