[mapserver-users] SQL Server 2008 and WFS Service
geographika
geographika at gmail.com
Mon Aug 2 16:26:15 EDT 2010
On 24/07/2010 23:25, Tamas Szekeres wrote:
> 2010/7/24 geographika <geographika at gmail.com
> <mailto:geographika at gmail.com>>
> Has anyone successfully created a WFS service using the SQL Server
> 2008 plug in?
> I followed the steps at http://mapserver.org/ogc/wfs_server.html,
> and get no errors when running a
> SERVICE=WFS&VERSION=1.0.0&REQUEST=getcapabilities request.
> However when trying to retrieve the features using a feature
> request
> (&SERVICE=WFS&VERSION=1.0.0&REQUEST=getfeature&TYPENAME=RoadsWFS)
> I don't get any GML. There are no errors in the MapServer log
> file. I don't believe this GET request requires a proxy and I get
> the same result on the server itself.
> I ran SQL Server profiler and the results and geometry are being
> correctly queried from the database. A shortened version of the
> SQL is below (several attributes removed):
> SELECT convert(varchar(max),
> RoadID),GEOM.STAsBinary(),convert(varchar(20), ROADID) from
> RoadNetwork2 WHERE
> GEOM.STIntersects(Geometry::STGeomFromText('POLYGON((-710069
> 7038976,-683731 7038976,-683731 7059350,-710069 7059350,-710069
> 7038976))',3785)) = 1
> I think there may be an issue due to none of the columns having names.
> Hi
> I've just tried with the recent version of the mssql2008 driver and it
> works for me. Which mapserver version are you testing with?
> I would recommend to do a test with one of the daily build packages
> from: http://vbkto.dyndns.org/sdk/
> If your problem still persists, feel free to open a ticket, attach
> your mapfile, sample requests and test data (ie. a shapefile) to be
> uploaded to the mssql2008 server.
> Best regards,
> Tamas
Tamas - I should have followed your first suggestion! I downloaded a
more recently compiled version of MapServer and I now get geometry
returned through the WFS service.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100802/eb5999b8/attachment.html
