[mapserver-users] Layerswitcher all Layers in one Mapfile
Strunck, Alexander
strunck at bicc.de
Thu Aug 5 08:51:01 EDT 2010
Hello
i am just testing a layerswitcher. First i programmed it so that every layer is in a separate mapfile. everything works fine.
now i want to try to put all layers in one mapfile. but now if i want to turn a layer on, i get the message
msWMSLoadGetMapParams():WMS server error. Invalid layer(s) given in the LAYERS parameter.
the html file looks like this
var bicc_wms = new OpenLayers.Layer.WMS(
"baselayer",
"****/cgi-bin/mapserv",
map: '/var/www/map_data/umn/allinone.map',
layers: 'baselayer',
format: 'image/png',
transparent: 'false'
{isBaseLayer: true, visibility: false}
layer_test1 = new OpenLayers.Layer.WMS(
"milex",
layers: "milex",
transparent: "true",
format: "image/png"
{isBaseLayer: false, visibility: false}
the part of the mapfile looks like this
LAYER
NAME 'baselayer'
GROUP 'baselayer'
TYPE Polygon
INCLUDE 'postgis.config'
DATA 'the_geom from (SELECT c.gid, c.the_geom AS the_geom FROM basemap AS c ) as foo using unique gid using SRID=4326'
STATUS on
METADATA
WMS_TITLE 'Grenzen aller Länder'
WMS_FEATURE_INFO_MIME_TYPE 'text/html'
END #METADATA
CLASS
NAME 'Grenzen aller Länder'
STYLE
COLOR 211 211 211
OUTLINECOLOR 1 1 1
END #STYLE
END # CLASS
# LayerGroup Klassen Militärausgaben #
LAYER
NAME 'milex'
TYPE Polygon
DATA 'the_geom from (SELECT c.gid, gmi.c_milex AS rank, c.the_geom AS the_geom FROM basemap AS c LEFT JOIN m3_thema1_2008_2 AS gmi ON c.iso3_code = gmi.iso3_code) as foo using unique gid using SRID=4326'
STATUS off
METADATA
WMS_TITLE 'Country Boundaries'
END #METADATA
CLASS
NAME 'no data available'
EXPRESSION ([rank] eq 999)
STYLE
COLOR 211 211 211
OUTLINECOLOR 1 1 1
END #STYLE
END # CLASS
has someone an idea??
thx
alex
Internationales Konversionszentrum Bonn
Bonn International Center for Conversion (BICC) GmbH
Pfarrer- Byns-Straße 1, 53121 Bonn, GERMANY
Tel. / Phone: +49-228-911 96 0, Fax: +49-228-911 96 - 22
Internet: www.bicc.de, E-mail: bicc at bicc.de
Firmensitz/ Office: Bonn
Registergericht/ Registered at: Amtsgericht Bonn, HRB 6717
Geschäftsführer/ Director: Peter Johannes Croll
Prokurist/ Authorized Signatory: Michael Dedek
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100805/0f45246e/attachment.html
