[mapserver-users] Vector symbol drawing problem
thomas bonfort
thomas.bonfort at gmail.com
Tue Aug 10 12:12:45 EDT 2010
In your examples you only set the width of the stroke for your symbol. What
you want is size 10, width 1.
Regards,
> David,
> As you may have noticed, I've just submitted a bug for this - ticket
#3511. In the meantime, I'm drawing thin horizontal rectangles instead,
although these don't get rendered either if they're less than 0.05 units
(pixels?) high! :-(
> Jez
> -----Original Message-----
> From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us]
> Sent: Monday 9 August 2010 18:59
> To: Jez Walters
> Subject: RE: [mapserver-users] Vector symbol drawing problem
> Thomas is the guy who knows what he is talking about, he wrote much of the
agg rendering code.
> I hadn't had enough coffee this morning to give you a reasonable answer...
> David.
> From: Jez Walters [mailto:Jez.Walters at ipl.com]
> Sent: Monday, August 09, 2010 11:31 AM
> To: Fawcett, David (MPCA)
> Cc: 'mapserver-users at lists.osgeo.org'
> Hi David,
> Just in case it makes any difference, I'm attempting to draw the UK
Ordnance Survey MasterMap Topography Layer. Here's a sample map file that
demonstrates the problem - although for some reason the VerticalLine symbol
now gets drawn horizontally!
> MAP
> NAME "IPMap"
> EXTENT 529445 179961 529555 180038 # The Mall, London
> SIZE 1200 1200
> UNITS meters
> IMAGETYPE PNG24
> IMAGECOLOR 190 255 255
> FONTSET "Fonts.lst"
> SHAPEPATH "."
> PROJECTION
> "init=epsg:27700" # OSGB39
> END
> SYMBOL
> NAME "HorizontalLine"
> TYPE vector
> POINTS
> 0 0
> 1 0
> END
> END
> SYMBOL
> NAME "VerticalLine"
> TYPE vector
> POINTS
> 0 0
> 0 1
> END
> END
> LAYER
> NAME "TopographicPoint"
> STATUS off
> TYPE point
> UNITS meters
> MINSCALEDENOM 0
> MAXSCALEDENOM 3125
> TRANSPARENCY alpha
> TILEINDEX "OSMasterMap/TopographyLayer/TopographicPoint"
> CLASS
> STYLE
> SYMBOL "HorizontalLine"
> COLOR 0 0 0
> WIDTH 10
> END
> END
> END
> END
> Regards,
> Jez
> Sent: Monday 9 August 2010 17:03
> To: Jez Walters; mapserver-users at lists.osgeo.org
> What does the rest of the map file look like? What is your map extent?
> David.
> From: mapserver-users-bounces at lists.osgeo.org [mailto:
mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jez Walters
> Sent: Monday, August 09, 2010 11:00 AM
> To: mapserver-users at lists.osgeo.org
> Subject: [mapserver-users] Vector symbol drawing problem
> Hello fellow MapServer users!
> I'm trying to draw a really simple vector SYMBOL using MapServer - it's
just
> a straight line! I expected this to be easy, but I can only get MapServer
> to render vertical lines! The following SYMBOL definition correctly draws
a
> vertical line:
> SYMBOL
> NAME "VerticalLine"
> TYPE VECTOR
> POINTS
> 0 0
> 0 1
> END
> END
> However, when I change this to draw a horizontal line nothing is output:
> SYMBOL
> TYPE VECTOR
> POINTS
> 0 0
> 1 0
> END
> END
> Is this a bug or am I doing something wrong?
> Jez
http://osgeo-org.1803224.n2.nabble.com/Vector-symbol-drawing-problem-tp5389524p5389524.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> The information transmitted is intended only for the person
> or entity to which it is addressed and may contain
> confidential and/or privileged material. If you are not the
> addressee, any disclosure, reproduction, copying,
> distribution, or other dissemination or use of this
> communication is strictly prohibited. If you have received
> this transmission in error please notify the sender
> immediately and then delete this email.
> Any representations or commitments expressed in this email
> are subject to contract.
> This message has been scanned for viruses and dangerous
> content. However, it is essential that the recipient also
> checks this message using commercially available mail
> scanning and anti-virus software. IPL Information Processing
> Limited accepts no liability for any loss or damage resulting
> from any virus or other dangerous content in this message.
> IPL Information Processing Limited is registered in England
> and Wales under company registration number 1418818.
> Registration took place at Cardiff on 10 May 1979. IPL
> Information Processing Limited's registered office and
> normal place of business is Eveleigh House, Grove Street,
> Bath, BA1 5LR, United Kingdom. IPL is also registered for
> Value Added Tax (VAT) under registration number GB 601 2931 83.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100810/72012eda/attachment.html
