[mapserver-users] GeoRaster via gdal on Ubuntu
Jeff McKenna
jmckenna at gatewaygeomatics.com
Wed Aug 11 08:42:34 EDT 2010
Sebastian,
I haven't tried an Oracle Spatial GeoRaster yet, but you might want to
use the shp2img commandline utility to test your mapfile
(http://www.mapserver.org/utilities/shp2img.html) and you can report
what shp2img exactly returns to this email list.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://www.gatewaygeomatics.com/
Sebastian E. Ovide wrote:
> Thanks Ivan, actually that was one of my starting points. Still no luck.
> as Gdal is working correctly (and all the variables has be re defined
> within <Location "/cgi-bin/"> as explained in that page)...the main
> question would be how to make MapServ bind correctly to gdal ?
> Is it possible that I am missing something in the map file ?
> LAYER
> NAME sebas
> TYPE RASTER
> STATUS ON
> DATA
> "georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1"
> END
> is there any keyword to use gdal ?
> On Wed, Aug 11, 2010 at 12:23 PM, Lucena, Ivan <ivan.lucena at pmldnet.com
> <mailto:ivan.lucena at pmldnet.com>> wrote:
> Sebastian,
> Have you take a look on that page:
> http://mapserver.org/installation/oracle.html
> It is about GDAL/OGR/OCI but all the system settings experiments are
> applicable to GDAL/GeoRaster too.
> Regards,
> Ivan
> Hi All,
> I've installed MapServer via ubuntugis repo and build gdal by
> hand in order to support oracle
> sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG
> OUTPUT=WBMP OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
> SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER
> SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
> INPUT=SHAPEFILE
> sebas at SeansPC:~/mapserver$ gdalinfo --version
> GDAL 1.7.2, released 2010/04/23
> sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
> GeoRaster (rw+): Oracle Spatial GeoRaster
> sebas at SeansPC:~/mapserver$ which gdalinfo
> /home/sebas/gdal/bin/gdalinfo
> now I'm trying to use MapServer with gdal to read GeoRasters but
> I'm getting this error:
> and from command line:
> Driver: GeoRaster/Oracle Spatial GeoRaster
> Files: none associated
> Size is 24402, 49770
> Coordinate System is:
> PROJCS["British National Grid",
> GEOGCS["Ordnance Survey Great Brit",
> DATUM["Ordnance Survey Great Brit",
> SPHEROID["Airy
> 1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
> PRIMEM["Greenwich",0.000000],
> UNIT["Decimal Degree",0.01745329251994330]],
> PROJECTION["Transverse_Mercator"],
> PARAMETER["Scale_Factor",0.9996012717],
> PARAMETER["Central_Meridian",-2.000000],
> PARAMETER["Latitude_Of_Origin",49.000000],
> PARAMETER["False_Easting",400000.000000],
> PARAMETER["False_Northing",-100000.000000],
> UNIT["Meter",1.000000000000]]
> Origin = (49950.000000000000000,1250050.000000000000000)
> Pixel Size = (25.000000000000000,-25.000000000000000)
> Image Structure Metadata:
> INTERLEAVE=PIXEL
> COMPRESSION=DEFLATE
> Corner Coordinates:
> Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W,
> 60d58'39.59"N)
> Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W,
> 49d50'57.59"N)
> Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d
> 2'50.13"N)
> Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E,
> 49d53'42.66"N)
> Center ( 354975.000, 627925.000) ( 2d42'48.98"W,
> 55d32'34.62"N)
> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
> NoData Value=255
> Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110,
> 762x1555, 381x777, 190x388, 95x194
> So I suspects that MapServer is using the wrong gdal...
> is gdal binding hardcoded into MapServer ? or MapServer would
> use gdal from the path ?
> Thanks
> Sebastian E. Ovide
