[mapserver-users] GeoRaster via gdal on Ubuntu
Sebastian E. Ovide
sebastian.ovide at gmail.com
Wed Aug 11 06:33:37 EDT 2010
Hi All,
I've installed MapServer via ubuntugis repo and build gdal by hand in order
to support oracle
sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
INPUT=SHAPEFILE
sebas at SeansPC:~/mapserver$ gdalinfo --version
GDAL 1.7.2, released 2010/04/23
sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
GeoRaster (rw+): Oracle Spatial GeoRaster
sebas at SeansPC:~/mapserver$ which gdalinfo
/home/sebas/gdal/bin/gdalinfo
now I'm trying to use MapServer with gdal to read GeoRasters but I'm getting
this error:
georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1
and from command line:
Driver: GeoRaster/Oracle Spatial GeoRaster
Files: none associated
Size is 24402, 49770
Coordinate System is:
PROJCS["British National Grid",
GEOGCS["Ordnance Survey Great Brit",
DATUM["Ordnance Survey Great Brit",
SPHEROID["Airy
1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
PRIMEM["Greenwich",0.000000],
UNIT["Decimal Degree",0.01745329251994330]],
PROJECTION["Transverse_Mercator"],
PARAMETER["Scale_Factor",0.9996012717],
PARAMETER["Central_Meridian",-2.000000],
PARAMETER["Latitude_Of_Origin",49.000000],
PARAMETER["False_Easting",400000.000000],
PARAMETER["False_Northing",-100000.000000],
UNIT["Meter",1.000000000000]]
Origin = (49950.000000000000000,1250050.000000000000000)
Pixel Size = (25.000000000000000,-25.000000000000000)
Image Structure Metadata:
INTERLEAVE=PIXEL
COMPRESSION=DEFLATE
Corner Coordinates:
Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W, 60d58'39.59"N)
Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W, 49d50'57.59"N)
Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d 2'50.13"N)
Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E, 49d53'42.66"N)
Center ( 354975.000, 627925.000) ( 2d42'48.98"W, 55d32'34.62"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
NoData Value=255
Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110, 762x1555,
381x777, 190x388, 95x194
So I suspects that MapServer is using the wrong gdal...
is gdal binding hardcoded into MapServer ? or MapServer would use gdal from
the path ?
Thanks
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/67b9bfb4/attachment.html
