[mapserver-users] Vector symbol drawing problem
Jez Walters
Jez.Walters at ipl.com
Wed Aug 11 08:35:40 EDT 2010
David,
Thanks for the advice, but I've decided to draw a thin rectangle until this fault is fixed in MapServer - although the rectangle has to be at least 0.05 pixels high to be rendered.
SYMBOL
NAME "HorizontalLine" # Actually a thin rectangle!
TYPE vector
POINTS
-0.5 0
-0.5 0.05 # Required to force drawing!
0.5 0
-0.5 0 # Required to force drawing!
END
END
Regards,
Jez
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Fawcett, David (MPCA)
Sent: Tuesday 10 August 2010 16:50
To: Jez Walters
Cc: 'mapserver-users at lists.osgeo.org'
Subject: RE: [mapserver-users] Vector symbol drawing problem
Is there a TrueType symbol that you could use in place of the simple vector symbol? You could even potentially create your own if you can't find an existing one.
David.
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Jez Walters
Sent: Tuesday, August 10, 2010 4:25 AM
To: Fawcett, David (MPCA)
David,
As you may have noticed, I've just submitted a bug for this - ticket #3511. In the meantime, I'm drawing thin horizontal rectangles instead, although these don't get rendered either if they're less than 0.05 units (pixels?) high! :-(
Jez
From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us]
Sent: Monday 9 August 2010 18:59
To: Jez Walters
Thomas is the guy who knows what he is talking about, he wrote much of the agg rendering code.
I hadn't had enough coffee this morning to give you a reasonable answer...
David.
Sent: Monday, August 09, 2010 11:31 AM
Hi David,
Just in case it makes any difference, I'm attempting to draw the UK Ordnance Survey MasterMap Topography Layer. Here's a sample map file that demonstrates the problem - although for some reason the VerticalLine symbol now gets drawn horizontally!
MAP
NAME "IPMap"
EXTENT 529445 179961 529555 180038 # The Mall, London
SIZE 1200 1200
UNITS meters
IMAGETYPE PNG24
IMAGECOLOR 190 255 255
FONTSET "Fonts.lst"
SHAPEPATH "."
PROJECTION
"init=epsg:27700" # OSGB39
END
SYMBOL
TYPE vector
POINTS
0 0
1 0
END
END
SYMBOL
NAME "VerticalLine"
TYPE vector
POINTS
0 0
0 1
END
END
LAYER
NAME "TopographicPoint"
STATUS off
TYPE point
UNITS meters
MINSCALEDENOM 0
MAXSCALEDENOM 3125
TRANSPARENCY alpha
TILEINDEX "OSMasterMap/TopographyLayer/TopographicPoint"
CLASS
STYLE
SYMBOL "HorizontalLine"
COLOR 0 0 0
WIDTH 10
END
END
END
END
Regards,
Jez
Sent: Monday 9 August 2010 17:03
To: Jez Walters; mapserver-users at lists.osgeo.org
What does the rest of the map file look like? What is your map extent?
David.
Sent: Monday, August 09, 2010 11:00 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Vector symbol drawing problem
Hello fellow MapServer users!
I'm trying to draw a really simple vector SYMBOL using MapServer - it's just
a straight line! I expected this to be easy, but I can only get MapServer
to render vertical lines! The following SYMBOL definition correctly draws a
vertical line:
SYMBOL
NAME "VerticalLine"
TYPE VECTOR
POINTS
0 0
0 1
END
END
However, when I change this to draw a horizontal line nothing is output:
SYMBOL
TYPE VECTOR
POINTS
0 0
1 0
END
END
Is this a bug or am I doing something wrong?
Jez
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vector-symbol-drawing-problem-tp5389524p5389524.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
