[mapserver-users] GeoRaster via gdal on Ubuntu
Sebastian E. Ovide
sebastian.ovide at gmail.com
Wed Aug 11 07:45:40 EDT 2010
Thanks Ivan, actually that was one of my starting points. Still no luck.
as Gdal is working correctly (and all the variables has be re defined within
<Location "/cgi-bin/"> as explained in that page)...the main question would
be how to make MapServ bind correctly to gdal ?
Is it possible that I am missing something in the map file ?
LAYER
NAME sebas
TYPE RASTER
STATUS ON
DATA
"georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1"
END
is there any keyword to use gdal ?
On Wed, Aug 11, 2010 at 12:23 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Sebastian,
> Have you take a look on that page:
> http://mapserver.org/installation/oracle.html
> It is about GDAL/OGR/OCI but all the system settings experiments are
> applicable to GDAL/GeoRaster too.
> Regards,
> Ivan
> Sebastian E. Ovide wrote:
>> Hi All,
>> I've installed MapServer via ubuntugis repo and build gdal by hand in
>> order to support oracle
>> sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
>> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>> INPUT=SHAPEFILE
>> sebas at SeansPC:~/mapserver$ gdalinfo --version
>> GDAL 1.7.2, released 2010/04/23
>> sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
>> GeoRaster (rw+): Oracle Spatial GeoRaster
>> sebas at SeansPC:~/mapserver$ which gdalinfo
>> /home/sebas/gdal/bin/gdalinfo
>> now I'm trying to use MapServer with gdal to read GeoRasters but I'm
>> getting this error:
>> and from command line:
>> Driver: GeoRaster/Oracle Spatial GeoRaster
>> Files: none associated
>> Size is 24402, 49770
>> Coordinate System is:
>> PROJCS["British National Grid",
>> GEOGCS["Ordnance Survey Great Brit",
>> DATUM["Ordnance Survey Great Brit",
>> SPHEROID["Airy
>> 1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
>> PRIMEM["Greenwich",0.000000],
>> UNIT["Decimal Degree",0.01745329251994330]],
>> PROJECTION["Transverse_Mercator"],
>> PARAMETER["Scale_Factor",0.9996012717],
>> PARAMETER["Central_Meridian",-2.000000],
>> PARAMETER["Latitude_Of_Origin",49.000000],
>> PARAMETER["False_Easting",400000.000000],
>> PARAMETER["False_Northing",-100000.000000],
>> UNIT["Meter",1.000000000000]]
>> Origin = (49950.000000000000000,1250050.000000000000000)
>> Pixel Size = (25.000000000000000,-25.000000000000000)
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> COMPRESSION=DEFLATE
>> Corner Coordinates:
>> Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W, 60d58'39.59"N)
>> Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W, 49d50'57.59"N)
>> Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d 2'50.13"N)
>> Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E, 49d53'42.66"N)
>> Center ( 354975.000, 627925.000) ( 2d42'48.98"W, 55d32'34.62"N)
>> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
>> NoData Value=255
>> Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110, 762x1555,
>> 381x777, 190x388, 95x194
>> So I suspects that MapServer is using the wrong gdal...
>> is gdal binding hardcoded into MapServer ? or MapServer would use gdal
>> from the path ?
>> Thanks
>> Sebastian E. Ovide
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/52fd788a/attachment.html
