[mapserver-users] Vector symbol drawing problem
Jez Walters
Jez.Walters at ipl.com
Wed Aug 11 08:29:44 EDT 2010
Thomas,
I still don’t get any horizontal line drawn, even after setting the size and width as you recommended. For what it’s worth, I’m not convinced that your size and width are what I want anyway, since a vertical line with these dimensions is drawn way too big – but thanks for the suggestion!
Warm regards,
Jez
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of thomas bonfort
Sent: Tuesday 10 August 2010 17:13
To: Jez Walters
Cc: mapserver-users at lists.osgeo.org
Subject: Re: RE: [mapserver-users] Vector symbol drawing problem
In your examples you only set the width of the stroke for your symbol. What you want is size 10, width 1.
Regards,
> David,
> As you may have noticed, I've just submitted a bug for this - ticket #3511. In the meantime, I'm drawing thin horizontal rectangles instead, although these don't get rendered either if they're less than 0.05 units (pixels?) high! :-(
> Jez
> -----Original Message-----
> From: Fawcett, David (MPCA) [mailto:David.Fawcett at state.mn.us<mailto:David.Fawcett at state.mn.us>]
> Sent: Monday 9 August 2010 18:59
> To: Jez Walters
> Subject: RE: [mapserver-users] Vector symbol drawing problem
> Thomas is the guy who knows what he is talking about, he wrote much of the agg rendering code.
> I hadn't had enough coffee this morning to give you a reasonable answer...
> David.
> From: Jez Walters [mailto:Jez.Walters at ipl.com<mailto:Jez.Walters at ipl.com>]
> Sent: Monday, August 09, 2010 11:31 AM
> To: Fawcett, David (MPCA)
> Cc: 'mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>'
> Hi David,
> Just in case it makes any difference, I'm attempting to draw the UK Ordnance Survey MasterMap Topography Layer. Here's a sample map file that demonstrates the problem - although for some reason the VerticalLine symbol now gets drawn horizontally!
> MAP
> NAME "IPMap"
> EXTENT 529445 179961 529555 180038 # The Mall, London
> SIZE 1200 1200
> UNITS meters
> IMAGETYPE PNG24
> IMAGECOLOR 190 255 255
> FONTSET "Fonts.lst"
> SHAPEPATH "."
> PROJECTION
> "init=epsg:27700" # OSGB39
> END
> SYMBOL
> NAME "HorizontalLine"
> TYPE vector
> POINTS
> 0 0
> 1 0
> END
> END
> SYMBOL
> NAME "VerticalLine"
> TYPE vector
> POINTS
> 0 0
> 0 1
> END
> END
> LAYER
> NAME "TopographicPoint"
> STATUS off
> TYPE point
> UNITS meters
> MINSCALEDENOM 0
> MAXSCALEDENOM 3125
> TRANSPARENCY alpha
> TILEINDEX "OSMasterMap/TopographyLayer/TopographicPoint"
> CLASS
> STYLE
> SYMBOL "HorizontalLine"
> COLOR 0 0 0
> WIDTH 10
> END
> END
> END
> END
> Regards,
> Jez
> Sent: Monday 9 August 2010 17:03
> To: Jez Walters; mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> What does the rest of the map file look like? What is your map extent?
> David.
> From: mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org> [mailto:mapserver-users-bounces at lists.osgeo.org<mailto:mapserver-users-bounces at lists.osgeo.org>] On Behalf Of Jez Walters
> Sent: Monday, August 09, 2010 11:00 AM
> To: mapserver-users at lists.osgeo.org<mailto:mapserver-users at lists.osgeo.org>
> Subject: [mapserver-users] Vector symbol drawing problem
> Hello fellow MapServer users!
> I'm trying to draw a really simple vector SYMBOL using MapServer - it's just
> a straight line! I expected this to be easy, but I can only get MapServer
> to render vertical lines! The following SYMBOL definition correctly draws a
> vertical line:
> SYMBOL
> NAME "VerticalLine"
> TYPE VECTOR
> POINTS
> 0 0
> 0 1
> END
> END
> However, when I change this to draw a horizontal line nothing is output:
> SYMBOL
> TYPE VECTOR
> POINTS
> 0 0
> 1 0
> END
> END
> Is this a bug or am I doing something wrong?
> Jez
> View this message in context: http://osgeo-org.1803224.n2.nabble.com/Vector-symbol-drawing-problem-tp5389524p5389524.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
The information transmitted is intended only for the person
or entity to which it is addressed and may contain
confidential and/or privileged material. If you are not the
addressee, any disclosure, reproduction, copying,
distribution, or other dissemination or use of this
communication is strictly prohibited. If you have received
this transmission in error please notify the sender
immediately and then delete this email.
Any representations or commitments expressed in this email
are subject to contract.
This message has been scanned for viruses and dangerous
content. However, it is essential that the recipient also
checks this message using commercially available mail
scanning and anti-virus software. IPL Information Processing
Limited accepts no liability for any loss or damage resulting
from any virus or other dangerous content in this message.
IPL Information Processing Limited is registered in England
and Wales under company registration number 1418818.
Registration took place at Cardiff on 10 May 1979. IPL
Information Processing Limited's registered office and
normal place of business is Eveleigh House, Grove Street,
Bath, BA1 5LR, United Kingdom. IPL is also registered for
Value Added Tax (VAT) under registration number GB 601 2931 83.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/1465bc80/attachment-0001.html
