[mapserver-users] GeoRaster via gdal on Ubuntu
Sebastian E. Ovide
sebastian.ovide at gmail.com
Wed Aug 11 11:06:10 EDT 2010
Hi Cristiano,
I've tried the "dirty trick"..
sebas at SeansPC:/usr/lib$ ls -la libgdal1*
-rw-r--r-- 1 root root 7476096 2010-03-13 08:59 libgdal1.6.0.so.1.13.3
lrwxrwxrwx 1 root root 22 2010-04-30 14:19 libgdal1.6.0.so.1.seb ->
-rw-r--r-- 1 root root 17994558 2010-05-19 14:05 libgdal1.7.0.a
-rw-r--r-- 1 root root 8302832 2010-05-19 14:05 libgdal1.7.0.so.1.14.2
lrwxrwxrwx 1 root root 22 2010-05-20 07:57 libgdal1.7.0.so.1.seb ->
lrwxrwxrwx 1 root root 22 2010-05-20 07:57 libgdal1.7.0.so.seb ->
and yes... I'm getting an error in the log file:
[Wed Aug 11 15:56:10 2010] [error] [client 10.0.1.50]
/usr/lib/cgi-bin/mapserv: error while loading shared libraries:
libgdal1.7.0.so.1: cannot open shared object file: No such file or directory
so obviously MapServer is reading the wrong libgdal....
On Wed, Aug 11, 2010 at 2:01 PM, Cristiano Sumariva <sumariva at gmail.com>wrote:
> Well one dirty test you can do is rename the shared library gdal from .so
> to another name or remove it from your shared lib path.
> Then exec mapserver again.
> I think that if it is using shared lib then an error will be launched.
> I remember that one mapserver installation mine failed in a server update
> due to wrong symlink on shared libs.
> Try also ldconfig -l to see where your library loader is looking for
> libraries.
> 2010/8/11 Sebastian E. Ovide <sebastian.ovide at gmail.com>
> Thanks Ivan, actually that was one of my starting points. Still no luck.
>> as Gdal is working correctly (and all the variables has be re defined
>> within <Location "/cgi-bin/"> as explained in that page)...the main question
>> would be how to make MapServ bind correctly to gdal ?
>> Is it possible that I am missing something in the map file ?
>> LAYER
>> NAME sebas
>> TYPE RASTER
>> STATUS ON
>> DATA
>> "georaster:geoserver,geoserver,MFPRODUK_11G,LSLIDE_V5_RASTER,georaster,id=1"
>> END
>> is there any keyword to use gdal ?
>> On Wed, Aug 11, 2010 at 12:23 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
>>> Sebastian,
>>> Have you take a look on that page:
>>> http://mapserver.org/installation/oracle.html
>>> It is about GDAL/OGR/OCI but all the system settings experiments are
>>> applicable to GDAL/GeoRaster too.
>>> Regards,
>>> Ivan
>>> Sebastian E. Ovide wrote:
>>>> Hi All,
>>>> I've installed MapServer via ubuntugis repo and build gdal by hand in
>>>> order to support oracle
>>>> sebas at SeansPC:~/mapserver$ /usr/lib/cgi-bin/mapserv -v
>>>> MapServer version 5.6.5 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
>>>> OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE
>>>> SUPPORTS=ICONV SUPPORTS=FRIBIDI SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT
>>>> SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER
>>>> SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS SUPPORTS=GEOS
>>>> SUPPORTS=RGBA_PNG INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL
>>>> INPUT=SHAPEFILE
>>>> sebas at SeansPC:~/mapserver$ gdalinfo --version
>>>> GDAL 1.7.2, released 2010/04/23
>>>> sebas at SeansPC:~/mapserver$ gdalinfo --formats | grep GeoRaster
>>>> GeoRaster (rw+): Oracle Spatial GeoRaster
>>>> sebas at SeansPC:~/mapserver$ which gdalinfo
>>>> /home/sebas/gdal/bin/gdalinfo
>>>> now I'm trying to use MapServer with gdal to read GeoRasters but I'm
>>>> getting this error:
>>>> and from command line:
>>>> Driver: GeoRaster/Oracle Spatial GeoRaster
>>>> Files: none associated
>>>> Size is 24402, 49770
>>>> Coordinate System is:
>>>> PROJCS["British National Grid",
>>>> GEOGCS["Ordnance Survey Great Brit",
>>>> DATUM["Ordnance Survey Great Brit",
>>>> SPHEROID["Airy
>>>> 1830",6377563.396,299.3249646],375,-111,431,0,0,0,1],
>>>> PRIMEM["Greenwich",0.000000],
>>>> UNIT["Decimal Degree",0.01745329251994330]],
>>>> PROJECTION["Transverse_Mercator"],
>>>> PARAMETER["Scale_Factor",0.9996012717],
>>>> PARAMETER["Central_Meridian",-2.000000],
>>>> PARAMETER["Latitude_Of_Origin",49.000000],
>>>> PARAMETER["False_Easting",400000.000000],
>>>> PARAMETER["False_Northing",-100000.000000],
>>>> UNIT["Meter",1.000000000000]]
>>>> Origin = (49950.000000000000000,1250050.000000000000000)
>>>> Pixel Size = (25.000000000000000,-25.000000000000000)
>>>> Image Structure Metadata:
>>>> INTERLEAVE=PIXEL
>>>> COMPRESSION=DEFLATE
>>>> Corner Coordinates:
>>>> Upper Left ( 49950.000, 1250050.000) ( 8d28'31.89"W, 60d58'39.59"N)
>>>> Lower Left ( 49950.000, 5800.000) ( 6d52'14.32"W, 49d50'57.59"N)
>>>> Upper Right ( 660000.000, 1250050.000) ( 2d49'4.15"E, 61d 2'50.13"N)
>>>> Lower Right ( 660000.000, 5800.000) ( 1d37'14.80"E, 49d53'42.66"N)
>>>> Center ( 354975.000, 627925.000) ( 2d42'48.98"W, 55d32'34.62"N)
>>>> Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
>>>> NoData Value=255
>>>> Overviews: 12201x24885, 6100x12442, 3050x6221, 1525x3110, 762x1555,
>>>> 381x777, 190x388, 95x194
>>>> So I suspects that MapServer is using the wrong gdal...
>>>> is gdal binding hardcoded into MapServer ? or MapServer would use gdal
>>>> from the path ?
>>>> Thanks
>>>> Sebastian E. Ovide
>>>> _______________________________________________
>>>> mapserver-users mailing list
>>>> mapserver-users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/801d9367/attachment.html
