[mapserver-users] Openlayers + Bing Maps with Mapserver WMS
projection error...
Edward Mac Gillavry
emacgillavry at hotmail.com
Wed Aug 11 11:35:56 EDT 2010
Bing maps is also using EPSG: 900913, EPSG:3785 or EPSG:3857 whichever is the latest... That should do the trick.
HTH
Edward
Date: Wed, 11 Aug 2010 11:12:47 -0300
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Openlayers + Bing Maps with Mapserver WMS projection error...
Hey guys...
When using Bing maps as base layer, I have huge difference between my data ... Both are using WGS84 projection...
The image is attached...
Any idea?
Thanks
My WMS map:
MAP
PROJECTION
"+init=epsg:4326"
END
WEB
IMAGEPATH 'D:\Temp'
IMAGEURL '/tmp/'
QUERYFORMAT 'text/html'
METADATA
"wms_title" "WMS Server" ##required
"wms_onlineresource" "http://localhost/cgi-bin/mapserv.exe?" ##required
"wms_srs" "EPSG:4269 EPSG:4326 EPSG:42304 EPSG:42101 EPSG:900913" ##recommended
"wms_feature_info_mime_type" "text/html"
"labelcache_map_edge_buffer"
"-10"
END
END
LAYER
NAME STATE
METADATA
"wms_title" "STATE" ##required
END
TYPE polygon
STATUS ON
INCLUDE "Connection.map"
DATA "..."
PROCESSING "CLOSE_CONNECTION=DEFER"
PROCESSING "LABEL_NO_CLIP=ON"
PROJECTION
"init=epsg:4326"
END
My Openlayers config:
map = new OpenLayers.Map('Test', {
resolutions: [0.09524345064126273, 0.0730199788249681,
0.047621725320631365, 0.031747816880420915, 0.015873908440210457,
0.009524345064126272, 0.0031747816880420914, 0.0015873908440210457,
0.0007936954220105228, 0.00031747816880420915],
projection: "EPSG:4326",
displayProjection: new OpenLayers.Projection("EPSG:4326"),
tileSize: new OpenLayers.Size(400, 400),
maxExtent: new OpenLayers.Bounds(-102.2607421875, -46.142578125, 4.7021484375, 13.623046875)
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100811/ca5b6805/attachment-0001.html
