[mapserver-users] Offset values from database
Bob Basques
Bob.Basques at ci.stpaul.mn.us
Thu Aug 12 16:46:37 EDT 2010
All,
Wondering, would this work for INSIDE/OUTSIDE situations with regard to
polygon drawing? Or is the left/right sides of the line strictly
relying on the from/to aspects of how the polygon was drawn
(clockwise/counterclockwise) This would be handy for off-setting to
(ONLY) the inside of a polygon for example.
Thanks
bobb
>>> Wim Vanbelle <wimvanbelle at gmail.com> wrote:
Thank you very much everyone. And especially Thomas. That was indeed
what I was looking for. You saved me a lot of work!
Much appreciated.
On 12 August 2010 17:50, Fawcett, David (MPCA)
<David.Fawcett at state.mn.us>
wrote:
Thanks Thomas
That looks nice in my test example.
David.
-----Original Message-----
From: thomas bonfort [mailto:thomas.bonfort at gmail.com]
Sent: Thursday, August 12, 2010 10:45 AM
To: Fawcett, David (MPCA)
Cc: Wim Vanbelle; mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Offset values from database
the -99 is a special offset value that shifts the line as you are
looking for.
style
color 255 0 0
offset -2 -99
width 2
end
style
color 0 255 0
offset 2 -99
width 2
end
not perfect as there are artifacts on sharp angles, but worth a try.
regards,
thomas
On Thu, Aug 12, 2010 at 16:56, Fawcett, David (MPCA)
<David.Fawcett at state.mn.us> wrote:
> Wim,
> You can do these offsets in pixel values at a class level, just not a
> feature level. This pretty much does what you are describing, although
it
> gets a little funky when the lines are diagonal and not straight.
> CLASS
> STYLE
> COLOR 0 0 0
> WIDTH 2
> END
> STYLE
> COLOR 255 0 0
> WIDTH 2
> OFFSET 10 10
> END
> STYLE
> COLOR 0 255 0
> WIDTH 2
> OFFSET -10 -10
> END
> END
> David.
> From: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Wim
Vanbelle
> Sent: Thursday, August 12, 2010 9:32 AM
> To: mapserver-users at lists.osgeo.org
> Maybe this pic helps elaborate on what i'm trying to accomplish:
> http://fileshare.myroute.be/exchange/asymmetriclinedrawing.png
> It should be noted that the distance between the 2 (new) lines, should
be a
> fixed value over the zoomlevels. It must not be the case that at the
> furthest zoomlevel the lines are further apart.
> I've looked all over for this, but never really found a proper
solution. I
> tried cartographic symbol drawing, but it only draws on the same side
every
> time. Maybe I'm just doing it wrong :).
> On 12 August 2010 16:28, Wim Vanbelle <wimvanbelle at gmail.com> wrote:
> Hello,
> thanks for your feedback.
> The issue with this, is that the underlying linestrings (the 2 that
would
> lie on top of eachother), have different colors :(.
> So they have to be moved apart from one another. I have not found a
way to
> do this with asymmetric line drawing either, as it will always offset
to the
> same side.
> This is why i would need the offset value to be configurable in the
> database. I could select a different pixel offset for each line and
they
> would always appear next to eachtoher (no matter what zoomlevel).
> I can elaborate on the problem more if I am a little too confusing !
> On 12 August 2010 16:20, Cristiano Sumariva <sumariva at gmail.com>
wrote:
> If it is a display problem why not try create some special symbology
to
> overlap one line with another using different symbol strokes. So the
user
> will se that are 2 lines overlayed.
> 2010/8/12 Wim Vanbelle <wimvanbelle at gmail.com>
> Hi David,
> I read that documentation before though. I was hoping it just hadn't
been
> updated... Is this possibly a feature for 6.0 ?
> Are there any other ways how one could offset a feature in pixels,
rather
> than in lat/long coords?
> Maybe I should elaborate on the original problem a little. Cons
ider 2
line
> segments that lie> If you would however perform this code simply on lat/long values, it
would
> imply, that when scaling your map at the most detailed zoom level, the
lines
> would lie very far apart, and when zoomed out, they would appear to
lie on
> top of eachother.
> I find it hard to believe that I would need to pre calculate all the
data in
> order to obtain geometry objects for each zoom level.
> Maybe some veterans have some good insight in this :).
> On 12 August 2010 15:26, Fawcett, David (MPCA)
> wrote:
> Wim,
> If you don’t want me to tell you, you will likely want to look at the
> mapfile documentation at: http://mapserver.org/mapfile/style.html
> [Spoiler Alert]
> You can’t use values from an attribute table to set the value of this
> property
> [/Spoiler Alert]
> David.
Vanbelle
> Sent: Thursday, August 12, 2010 5:48 AM
> Subject: [mapserver-users] Offset values from database
> Hi,
> I'm trying to load offset X, Y data from the postgis database.
> Each feature has an offset value defined there.
> My mapfile (relevant part) looks like this:
> In the layer:
> DATA "geom_mercator from map_links using
> unique Id using SRID=900913"
> STYLE
> WIDTH 6
> COLOR 0 255 0
> ANTIALIAS TRUE
> ANGLE AUTO
> OFFSET [offsetX] [offsetY]
> END
> Please don't tell me the offsetX, Y values cannot be read from the
database.
> That would be a huge issue for me.
> Thank you for your time.
> Best regards
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100812/bf638041/attachment-0001.html
