[mapserver-users] logging GDAL queries
Sebastian E. Ovide
sebastian.ovide at gmail.com
Fri Aug 13 07:44:45 EDT 2010
sure...
sebas at SeansPC:~/mapserver/mapserver-5.6.5$ gdalinfo --version
GDAL 1.7.2, released 2010/04/23
georaster:geoserver,geoserver,MFPRODUK_11G,fluvd04q200pj,georaster,id=1 -mdd
oracle
Driver: GeoRaster/Oracle Spatial GeoRaster
Files: none associated
Size is 190325, 271423
Coordinate System is:
PROJCS["Popular Visualisation CRS / Mercator (deprecated)",
GEOGCS["Popular Visualisation CRS",
DATUM["Popular_Visualisation_Datum",
SPHEROID["Popular Visualisation Sphere",6378137,0,
AUTHORITY["EPSG","7059"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6055"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.01745329251994328,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4055"]],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
PROJECTION["Mercator_1SP"],
PARAMETER["central_meridian",0],
PARAMETER["scale_factor",1],
PARAMETER["false_easting",0],
PARAMETER["false_northing",0],
EXTENSION["PROJ4","+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
+lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +wktext
+no_defs"],
AUTHORITY["EPSG","3785"],
AXIS["X",EAST],
AXIS["Y",NORTH]]
Origin = (-703633.464883987908252,7805920.616936270147562)
Pixel Size = (4.999999999999999,-5.000000000000000)
Metadata (oracle):
TABLE_NAME=fluvd04q200pj
COLUMN_NAME=georaster
RDT_TABLE_NAME=RDT_FLUVD04Q200PJ
RASTER_ID=62
METADATA=<georasterMetadata xmlns="
http://xmlns.oracle.com/spatial/georaster">
<objectInfo>
<rasterType>20001</rasterType>
<isBlank>false</isBlank>
<defaultRed>1</defaultRed>
<defaultGreen>1</defaultGreen>
<defaultBlue>1</defaultBlue>
</objectInfo>
<rasterInfo>
<cellRepresentation>UNDEFINED</cellRepresentation>
<cellDepth>8BIT_U</cellDepth>
<NODATA>255</NODATA>
<totalDimensions>2</totalDimensions>
<dimensionSize type="ROW">
<size>271423</size>
</dimensionSize>
<dimensionSize type="COLUMN">
<size>190325</size>
</dimensionSize>
<ULTCoordinate>
<row>0</row>
<column>0</column>
</ULTCoordinate>
<blocking>
<type>REGULAR</type>
<totalRowBlocks>1061</totalRowBlocks>
<totalColumnBlocks>744</totalColumnBlocks>
<rowBlockSize>256</rowBlockSize>
<columnBlockSize>256</columnBlockSize>
</blocking>
<interleaving>BIP</interleaving>
<pyramid>
<type>DECREASE</type>
<resampling>NN</resampling>
<maxLevel>11</maxLevel>
</pyramid>
<compression>
<type>DEFLATE</type>
</compression>
</rasterInfo>
<spatialReferenceInfo>
<isReferenced>true</isReferenced>
<isRectified>true</isRectified>
<SRID>3785</SRID>
<spatialResolution dimensionType="X">
<resolution>5</resolution>
</spatialResolution>
<spatialResolution dimensionType="Y">
<modelCoordinateLocation>CENTER</modelCoordinateLocation>
<modelType>FunctionalFitting</modelType>
<polynomialModel rowOff="0" columnOff="0" xOff="0" yOff="0" zOff="0"
rowScale="1" columnScale="1" xScale="1" yScale="1" zScale="1">
<pPolynomial pType="1" nVars="2" order="1" nCoefficients="3">
<polynomialCoefficients>1561183.623387254 0
-0.2</polynomialCoefficients>
</pPolynomial>
<qPolynomial pType="1" nVars="0" order="0" nCoefficients="1">
<polynomialCoefficients>1</polynomialCoefficients>
</qPolynomial>
<rPolynomial pType="1" nVars="2" order="1" nCoefficients="3">
<polynomialCoefficients>140726.1929767976 0.2
0</polynomialCoefficients>
</rPolynomial>
<sPolynomial pType="1" nVars="0" order="0" nCoefficients="1">
</sPolynomial>
</polynomialModel>
</spatialReferenceInfo>
<layerInfo>
<layerDimension>BAND</layerDimension>
<objectLayer>
<layerNumber>0</layerNumber>
<layerDimensionOrdinate>0</layerDimensionOrdinate>
<layerID/>
<colorMap>
<colors>
<cell value="1" red="255" green="0" blue="0" alpha="100"/>
<cell value="2" red="0" green="255" blue="0" alpha="100"/>
<cell value="3" red="0" green="0" blue="255" alpha="100"/>
<cell value="4" red="150" green="50" blue="100" alpha="100"/>
<cell value="255" red="0" green="0" blue="0" alpha="0"/>
</colors>
</colorMap>
</objectLayer>
</layerInfo>
</georasterMetadata>
Image Structure Metadata:
INTERLEAVE=PIXEL
COMPRESSION=DEFLATE
Corner Coordinates:
Upper Left ( -703633.465, 7805920.617) ( 6d19'15.05"W, 57d 2'52.80"N)
Lower Left ( -703633.465, 6448805.617) ( 6d19'15.05"W, 49d49'30.04"N)
Upper Right ( 247991.535, 7805920.617) ( 2d13'39.89"E, 57d 2'52.80"N)
Lower Right ( 247991.535, 6448805.617) ( 2d13'39.89"E, 49d49'30.04"N)
Center ( -227820.965, 7127363.117) ( 2d 2'47.58"W, 53d35'23.19"N)
Band 1 Block=256x256 Type=Byte, ColorInterp=Gray
NoData Value=255
Overviews: 95162x135711, 47581x67855, 23790x33927, 11895x16963, 5947x8481,
2973x4240, 1486x2120, 743x1060, 371x530, 185x265, 92x132
On Fri, Aug 13, 2010 at 12:32 PM, Lucena, Ivan <ivan.lucena at pmldnet.com>wrote:
> Interesting.
> Can you post your gdalinfo report with "-mdd oracle" option?
> What are the versions your are running (GDAL,Oracle)?
> Older version of the driver used to run a new query every time you change
> levels.
> Sebastian E. Ovide wrote:
>> yep I did... and the weir thing is that generating the images from "far
>> away" zoom under 12... it performs very well... not sure why it doesn't in
>> the levels 13-17.... for that reason I was trying to find the SQL
>> queries....
>> On Fri, Aug 13, 2010 at 12:01 PM, Lucena, Ivan <ivan.lucena at pmldnet.com<mailto:
>> ivan.lucena at pmldnet.com>> wrote:
>> Sebastian,
>> Hi All
>> I am using MapServer + GDAL to render GeoRasters and I am having
>> very poor performance reading GeoRasters at a high zoom level...
>> over 13... it would take even 20 seconds per tile...
>> Did you generate pyramids?
>> Is it possible to log the GDAL queries that MapServer is doing?
>> (and the SQL queries that GDAL is doing ?)
>> thanks
>> -- Sebastian E. Ovide
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> <mailto:mapserver-users at lists.osgeo.org>
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Sebastian E. Ovide
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100813/3f282033/attachment-0001.html
