[mapserver-users] logging GDAL queries
Sebastian E. Ovide
sebastian.ovide at gmail.com
Fri Aug 13 07:46:42 EDT 2010
Thanks Bart... I can see the debug info and the queries now....
On Fri, Aug 13, 2010 at 9:36 AM, Bart van den Eijnden <bartvde at osgis.nl>wrote:
> Add CONFIG "CPL_DEBUG" "ON" to your MAP object in the MAP file. Probably
> wise to add DEBUG 5 to your MAP and LAYER as well.
> Also add something like:
> CONFIG "MS_ERRORFILE" "stderr" and then check your Apache error log.
> Best regards,
> Bart
> Looking for flexible support on OpenLayers or GeoExt? Please check out
> http://www.osgis.nl/support.html
> OSGIS
> bartvde at osgis.nl
> On Aug 13, 2010, at 10:33 AM, Sebastian E. Ovide wrote:
> > Hi All
> > I am using MapServer + GDAL to render GeoRasters and I am having very
> poor performance reading GeoRasters at a high zoom level... over 13... it
> would take even 20 seconds per tile...
> > Is it possible to log the GDAL queries that MapServer is doing? (and the
> SQL queries that GDAL is doing ?)
> > thanks
> > Sebastian E. Ovide
> > mapserver-users mailing list
> > mapserver-users at lists.osgeo.org
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
Sebastian E. Ovide
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100813/164b9842/attachment.html
