Re: [mapserver-users] logging GDAL queries
Ivan Lucena
ivan.lucena at pmldnet.com
Fri Aug 13 12:16:38 EDT 2010
Sebastian,
> -------Original Message-------
> From: Sebastian E. Ovide <sebastian.ovide at gmail.com>
> To: Ivan Lucena <ivan.lucena at pmldnet.com>
> Cc: mapserver-users at lists.osgeo.org
> Subject: Re: [mapserver-users] logging GDAL queries
> Sent: Aug 13 '10 09:27
> On Fri, Aug 13, 2010 at 1:59 PM, Ivan Lucena <[LINK:
> mailto:ivan.lucena at pmldnet.com] ivan.lucena at pmldnet.com> wrote:
> Sebastian,
> You are using a very small block size, maybe because you are also using
> ArcGIS products and they only support Oracle GeoRaster with 256x256
> blocking. Is that right?
> nop... I guess that 256x256 if the default gdal_translate block size ?
That is the default on GDAL/GeoRaster driver but you can change it using -co BLOCKXSIZE and -co BLOCKYSIZE.
But that would require you to load the image again (and generate Pyramids again...)
> Because of that, to access your GeoRaster object, the GDAL driver is
> requesting a very large array of BLOB (1000000 approximately). That can
> make your sever such-up memory from the machine where it is running and it
> is probably using virtual memory (disk) what is really slow.
> do you mean where MapServer is running ?
> top - 14:41:31 up 7 days, 6:20, 10 users, load average: 2.81, 1.92,
> 1.20
> Tasks: 340 total, 2 running, 338 sleeping, 0 stopped, 0 zombie
> Cpu(s): 11.8%us, 10.4%sy, 7.7%ni, 62.1%id, 0.0%wa, 0.0%hi,
> 8.0%si, 0.0%st
> Mem: 12331240k total, 5992136k used, 6339104k free, 189416k
> buffers
> Swap: 9084716k total, 703708k used, 8381008k free, 1481992k
> cached
> PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+
> COMMAND
> 24850 www-data 20 0 533m 330m 18m R 14 2.7 0:00.94
> mapserv
> 24852 www-data 20 0 532m 329m 18m S 19 2.7 0:01.22
> mapserv
> 24849 www-data 20 0 529m 326m 18m S 16 2.7 0:01.00
> mapserv
> 24851 www-data 20 0 517m 314m 18m S 13 2.6 0:00.96
> mapserv
> 24853 www-data 20 0 499m 296m 18m S 8 2.5 0:00.75
> mapserv
> 24854 www-data 20 0 470m 267m 18m S 5 2.2 0:00.53
> mapserv
Yeah. I am sorry. I called Mapserver a client :)
It is a Oracle client in that case. You probably have another nice machine running Oracle.
That is not the problem.
> It also uses some memory on the client side just to hold the array too
> but if you are running everything (Mapserver,Oracle) on the same machine
> that will adds up.
> Oracle is running on another Machine... and is very likely that it is the
> bottle neck...
Maybe not but I believe you have tools on Enterprise Manager to show the volume and speed of traffic.
> We are aware of that problem but it would be very helpful if you could
> file a bug report on GDAL's trac [[LINK: http://trac.osgeo.org/gdal/]
> http://trac.osgeo.org/gdal/] Thanks.
> I guess that the problem is that MapServer triys to read the whole map
> instead of reading only tile ???? is that correct ?
> Just as curiosity. Did you loaded that image with gdal_translate? How
> long it took and long does it takes to generate pyramids? Ha, you forgot to
> say what version of Oracle you are using.
> I loaded it with gdal in around 5 minutes... the pyramid (all levels) has
> been created overnight....
You original file was 51 Gb and it was loaded in 5 minutes !
See, forget all about network traffic. That is just great.
Note that it doesn't matter if you generate pyramids on PL/SQL or gdaladdo, the GDAL driver will call the same PL/SQL statement that you would write yourself.
So I believe that the problem is that Mapserver need to call GDALOpen() several times on that GeoRaster and that makes the GDAL driver to run the main-big-query several times. That needs to be addressed some how.
Regards,
Ivan
