[mapserver-users] Re: Raster Strategies Examples
Frank Warmerdam
warmerdam at pobox.com
Thu Aug 19 08:46:24 EDT 2010
Edi.Karadumi wrote:
> Sorry to bother again, when i use gdal_merge.py the part -ps 160 160, thats
> the pixel dimension and i get an image 1kb. The pixel size of the original
> file is 0.08 meters. So i think i should use 0.08x32 in the gdal_merge.py
> command?
Edi,
If the original resolution is 8cm then the 1/32nd overview should indeed
have a pixel size of 0.08x32 or 2.56m.
> And how many tiles should i merge together? Now i have 2T images
> and 2000Gb/32 = 62Gb the rezult image. Should i merge them all together and
> than recreate tiles? Even if i had 1200gb, 1200/32=37.5gb for an image not
> 1gb. That is still an image size that cant be handled
Note that the 1/32nd overview is reduced by a factor of 32 in x and y
so overall it will be original_size/(32*32). So 2TB would reduce to
about 1.95GB.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
