[mapserver-users] Re: Raster Strategies Examples
Edi.Karadumi
edikaradumi at gmail.com
Thu Aug 19 09:03:31 EDT 2010
Thanx to you my questions are comming to an end [?]
Three more last things
Should i retile the new mosaiced overview? Meaning should i create smaller
size tiles of the new mosaic?
And how can i find in which scale should i switch layers? So what will be
the maxscale of the original layer?
if ill still have performance problems, or ill get 1-2 terabytes of data
more should i make another mosaic with 0.08*16 or 0.08*8, or is there
another strategy?
On Thu, Aug 19, 2010 at 2:46 PM, Frank Warmerdam [via OSGeo.org] <
ml-node+5440051-1962745825-182671 at n2.nabble.com<ml-node%2B5440051-1962745825-182671 at n2.nabble.com>
> wrote:
> Edi.Karadumi wrote:
> > Sorry to bother again, when i use gdal_merge.py the part -ps 160 160,
> thats
> > the pixel dimension and i get an image 1kb. The pixel size of the
> original
> > file is 0.08 meters. So i think i should use 0.08x32 in the gdal_merge.py
> > command?
> Edi,
> If the original resolution is 8cm then the 1/32nd overview should indeed
> have a pixel size of 0.08x32 or 2.56m.
> > And how many tiles should i merge together? Now i have 2T images
> > and 2000Gb/32 = 62Gb the rezult image. Should i merge them all together
> and
> > than recreate tiles? Even if i had 1200gb, 1200/32=37.5gb for an image
> not
> > 1gb. That is still an image size that cant be handled
> Note that the 1/32nd overview is reduced by a factor of 32 in x and y
> so overall it will be original_size/(32*32). So 2TB would reduce to
> about 1.95GB.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, [hidden email]<http://user/SendEmail.jtp?type=node&node=5440051&i=0>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5440051&i=1>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Raster-Strategies-Examples-tp5363321p5440051.html
> To unsubscribe from Re: Raster Strategies Examples, click here<http://osgeo-org.1803224.n2.nabble.com/template/NodeServlet.jtp?tpl=unsubscribe_by_code&node=5439959&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDU0Mzk5NTl8LTE4NTQwODgxMTM=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Raster-Strategies-Examples-tp5363321p5440101.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100819/4f7af063/attachment.html
