[mapserver-users] Re: Raster Strategies Examples
Edi.Karadumi
edikaradumi at gmail.com
Thu Aug 19 09:50:50 EDT 2010
Sorry but im still not understanding this:
> That remains a complicated question. I believe I suggested 1/32 as a
> good overview level since beyond that point a normal map view will tend
> to involve a significant number of files.
My only problem now is to find the correct scale for each layer. I use
minscale and maxscale for the original layer and the mosaiced layer. So
since my data will be shown from 1:1500000 to 1:100 the minscale of the
original layer will be 100 and maxscale X. The minscale of the mosaic
overview will be X and the maxscale 1500000
original:
minscale 100
maxscale X
mosaic:
minscale X
maxscale 1500000
i cant find X?
On Thu, Aug 19, 2010 at 3:15 PM, Frank Warmerdam [via OSGeo.org] <
ml-node+5440161-2089753629-182671 at n2.nabble.com<ml-node%2B5440161-2089753629-182671 at n2.nabble.com>
> wrote:
> Edi.Karadumi wrote:
> > Thanx to you my questions are comming to an end
> > Three more last things
> > Should i retile the new mosaiced overview? Meaning should i create
> smaller
> > size tiles of the new mosaic? or 2Gb is not a problem
> Edi,
> Generally speaking, as long as you enable internal tiling when building
> the mosaic there is no need to break it down into separate files.
> Add '-co TILED=YES' to the gdal_merge.py command to produce an output
> GeoTIFF file that is internally tiled.
> > And how can i find in which scale should i switch layers? So what will be
> > the maxscale of the original layer?
> > if ill still have performance problems, or ill get 1-2 terabytes of data
> > more should i make another mosaic with 0.08*16 or 0.08*8, or is there
> > another strategy?
> I presume as you add data, your area is growing. If that is so, the 1/32nd
> overview level is still appropriate, and you just need to regenerate the
> overview for the larger area.
> If you are using MapServer and GDAL then there is no real problem with
> using
> one large geotiff file for the overview as long as it has internal tiling,
> even if it grows to many GB in size.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam, [hidden email]<http://user/SendEmail.jtp?type=node&node=5440161&i=0>
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
> [hidden email] <http://user/SendEmail.jtp?type=node&node=5440161&i=1>
> View message @
> http://osgeo-org.1803224.n2.nabble.com/Raster-Strategies-Examples-tp5363321p5440161.html
> To unsubscribe from Re: Raster Strategies Examples, click here<http://osgeo-org.1803224.n2.nabble.com/template/NodeServlet.jtp?tpl=unsubscribe_by_code&node=5440104&code=ZWRpa2FyYWR1bWlAZ21haWwuY29tfDU0NDAxMDR8LTE4NTQwODgxMTM=>.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/Raster-Strategies-Examples-tp5363321p5440310.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100819/e05500dc/attachment-0001.html
