[mapserver-users] maps all look squished
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Fri Aug 20 08:04:18 EDT 2010
What is the projection of your layer data, what is the projection for the output, and how do you request the image from Mapserver?
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Josh Jordan
Lähetetty: pe 20.8.2010 6:16
Vastaanottaja: mapserver-users at lists.osgeo.org
Aihe: [mapserver-users] maps all look squished
No matter what projection I use, my maps always look stretched too wide, or squished. What could be the problem? What can I do? Attached is a picture of the problem, the top michigan is correct, the bottom one is generated in mapserver.
Can anyone from Michigan suggest a projection where the state looks the most correct?
Thanks.
