[mapserver-users] RE: refactoring STYLEs ?
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Fri Aug 20 11:25:21 EDT 2010
There's a draft RFC floating around to support this but it hasn't gotten much love... You can use INCLUDEs to do something similar:
Main mapfile:
LAYER
NAME layer1
CLASS
INCLUDE 'style1.map'
END
END
LAYER
NAME layer2
CLASS
END
END
style1.map:
STYLE
COLOR 0 0 0
WIDTH 1
END
Ideally you'd be able to extend a base style which is what the RFC proposes. You can also do that with the INCLUDEs if you store just the style properties but not the block, eg.:
CLASS
STYLE
COLOR 255 0 0 # override color
END
END
and style1.map contains:
COLOR 0 0 0
WIDTH 1
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Clément MONIER
Sent: Friday, August 20, 2010 6:49 AM
To: 'mapserver-users at lists.osgeo.org'
Subject: [mapserver-users] refactoring STYLEs ?
Is it possible to add a style definition (inside a mapfile or elsewhere ) so that it wouldn't be necessary to repeat it for each layer ?
For instance :
2 layers with the same display style
LAYER
NAME layer1
CLASS
STYLE
COLOR 0 0 0
WIDTH 1
END
END
END
LAYER
NAME layer2
CLASS
STYLE
COLOR 0 0 0
WIDTH 1
END
END
END
STYLE 'style1'
STYLE
COLOR 0 0 0
WIDTH 1
END
END
LAYER
NAME layer1
CLASS
STYLE
'Style 1'
END
END
END
LAYER
NAME layer2
CLASS
STYLE
'Style 1'
END
END
END
Thanks & Regards
Clement
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100820/572a70f3/attachment-0001.html
