[mapserver-users] Using e00 files
Peter N. Schweitzer
pschweitzer at usgs.gov
Tue Feb 2 12:24:44 EST 2010
On 02/02/2010 11:32 AM, Jon Miner wrote:
> Now, I'm trying to layer on information from the GRANIT website:
> http://www.granit.unh.edu/
> ftp://ftp.granit.sr.unh.edu/pub/GRANIT_Data/Vector_Data/Transportation_Networks/d-railroads/rrnh.e00
> These files are "e00" files. Based on some other mailing list entries, I used the ogr2ogr command to convert the file into Shapefiles:
> ogr2ogr -f "ESRI Shapefile" temp ../data/rrnh.e00
> then copied the files into my data directory, and added a new layer to the map file:
> LAYER
> NAME "rail"
> TYPE LINE
> STATUS on
> DATA nhrail
> CLASS
> NAME "Railroads"
> SYMBOL 0
> COLOR 168 0 184
> END
> END
> Something is wrong since the line data does not get rendered. Maybe there is a better approach instead of converting to Shapefiles?
Jon,
The rr data are in NH state plane coordinates--are the other data you
are using in the same projection?
Peter
Peter N. Schweitzer (MS 954, U.S. Geological Survey, Reston, VA 20192)
(703) 648-6533 FAX: (703) 648-6252 email: pschweitzer at usgs.gov
<http://geology.usgs.gov/peter/>
