[mapserver-users] areas of high res
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Feb 3 00:23:50 EST 2010
That's why I am doing the tileindex editing exercise every time when we get updates for our imagery. I remove the totally covered old images from the tileindex but leave the overlapping ones. This way the double drawing is minimised. Have a try with shapefile editing, after doing it a few times it goes as fast as it takes to write how to do it.
-Jukka-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Christopher Schmidt
Lähetetty: ke 3.2.2010 3:35
Vastaanottaja: Wendell Turner
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] areas of high res
On Tue, Feb 02, 2010 at 11:34:05PM +0000, Wendell Turner wrote:
> On Tue, Feb 02, 2010 at 06:23:01PM -0500, Christopher Schmidt wrote:
> > On Tue, Feb 02, 2010 at 03:10:40PM -0800, TC Haddad wrote:
> > > use two different tile indexes and use MIN- and MAXSCALEDENOM to control
> > > when they are each used.
> Is that done by listing the higher res layer items after the
> lower res itesm in the arguments to gdaltindex? That appears
> to work, but is it loading tiles twice where the high res
> areas are?
Sure, or making two different layers in the mapfile. And yes,
it is. If you're in an 'edge' though, you'll want to have both
on, right? So when someone gets to the viewable edge they
don't end up with white/empty space? If so, there's not
any other practical option.
Regards,
Christopher Schmidt
MetaCarta
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
