[mapserver-users] php mapscript loadQuery problem
Daniel Morissette
dmorissette at mapgears.com
Tue Feb 9 15:00:49 EST 2010
Moen, Paul T. wrote:
> The right items are high lighted now but I get many of the following errors when I dumping the error stack.
> Error in msEvalExpression(): Cannot evaluate expression, no item index defined.
> This only seems to happen when there are many classes in the layer. Are these errors expected?
This would happen if you have classes with string constants (EXPRESSION
"...") or regular expressions (EXPRESSION /.../), but you did not
specify an ITEM in the layer definition (so MapServer has no attribute
value to use in matching the expression).
Daniel
Daniel Morissette
http://www.mapgears.com/
