[mapserver-users] Blank map when using WMS connection
Dejan Gambin
dejan.gambin at coin.hr
Fri Feb 26 16:38:24 EST 2010
David,
Thak you very much. It works now. Even I still don't know why this didn't work before. I am using p.mapper framework as my frontend and the wms example in it corectly shows after turning it on even its status is also set initially to OFF..
...probably I am missing something as I am pretty new in using WMS (maybe this is also the reason why the access to my WMS data is VERY slow :-)
regards, dejan
On 26. vel. 2010., at 18:53, Fawcett, David (MPCA) wrote:
Dejan,
I assume that you are adding the layer name to your URL call, if not, set the layer STATUS to DEFAULT.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Dejan Gambin
Sent: Friday, February 26, 2010 11:05 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] Blank map when using WMS connection
Maybe someone can give me a hint about this problem:
I am trying to show a map from an external WMS server. This is what I can do successfully from my browser (get the image displayed):
http://www.geo-portal.hr/wmsconnector/com.esri.wms.Esrimap/SCM?VERSION=1.1.1&REQUEST=GetMap&SERVICE=WMS&LAYERS=107&STYLE=&SRS=EPSG:31275&BBOX=5421243,5015282,5421607,5015717&WIDTH=400&HEIGHT=300&FORMAT=image/png
Now, if I define my layer like this:
MAP
PROJECTION
"init=epsg:31275"
END
LAYER
NAME "wms_test"
TYPE RASTER
STATUS OFF
CONNECTION "http://www.geo-portal.hr/wmsconnector/com.esri.wms.Esrimap/SCM?"
CONNECTIONTYPE WMS
PROJECTION
"init=epsg:31275"
END
METADATA
"DESCRIPTION" "WMS Test"
"wms_name" "107"
"wms_server_version" "1.1.1"
"wms_format" "image/png"
"wms_srs" "EPSG:31275"
END
END
...and try to show it (previously zoomed to the same extent as the one defined above by BBOX) I get nothing shown and there is no error in any log file.
Am I doing something wrong? I tried several combinations with wms_srs, projection (commenting some of them), etc. but nothing helps :-).
Thanks very much,
regards, dejan_______________________________________________
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
