[mapserver-users] Error configuring WMS app : Projection library
error. Invalid argument...
Frank Warmerdam
warmerdam at pobox.com
Tue Jan 5 10:03:10 EST 2010
stela anders wrote:
> LAYER
> NAME Argentina
> METADATA
> "wms_title" "Argentina" ##required
> END
> TYPE POLYGON
> STATUS ON
> INCLUDE "Connection.map"
> DATA "the_geom from tbl_argentina USING UNIQUE gid USING SRID=0"
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
> CLASS
> COLOR 255 200 255
> END
> END
> END
> When I try to open that with my OpenLayer app, I got images with that
> error :
> Error: msProcessProjection(): /Projection library error/. /Invalid argument
Stella,
I am not sure why you are getting this error. I search high and low and can't
find "Invalid argument" in either MapServer or PROJ.4. Are you working on
linux or Windows? Were the "/" characters really in this message? It is
hard for me to understand how this could happen.
With regard to your mapfile, I was surprised that you don't have
wms_srs metadata on your layer. It is a shot in the dark, but perhaps you
could add wms_srs EPSG:4326 metadata on the layer, and reorder the wms_srs
metadata on the map to put EPSG:4326 first.
Also, you could try changing:
> PROJECTION
> "proj=longlat"
> "ellps=WGS84"
> "datum=WGS84"
> "no_defs"
> END
to:
PROJECTION
"+init=epsg:4326"
END
in both the layer and map. This is slower to expand but it might
make it easier for mapserver to relate to epsg codes.
Best regards,
and watch the world go round - Rush | Geospatial Programmer for Rent
