[mapserver-users] 5.6.1 - GetFeatureInfo - template processing
Ted Spradley
tspradley at snoogems.com
Thu Jan 14 11:41:46 EST 2010
Hi everyone,
In version 5.4.1 the following GetFeatureInfo request url produced a table
described by templates for the
layer 'bldg_query' described below. With ver 5.6.1, Mapserver outputs only
the template from the
mapfile's WEB object (with no query results or image).
Do you have any idea of changes to make? To the request format? To the
mapfile?
Thank you all very much,
Ted S.
URL:
http://url.com/cgi-bin/mapserv?map=/path/to/cad.map
&SERVICE=WMS
&VERSION=1.1.1
&REQUEST=GetFeatureInfo
&SRS=EPSG%3A102740
&WIDTH=800&HEIGHT=800
&BBOX=3102785.400463,13832395.006499,3104115.230452,13833724.836488&LAYERS=building_comp_query
&STYLES=&FORMAT=image%2Fpng
&QUERY_LAYERS=bldg_query
&X=398&Y=390
&INFO_FORMAT=text/html
Relevant mapfile snippets:
MAP
NAME "CAD"
SIZE 800 800
EXTENT 2928849.796040 13748390.427723 3269286.273267
13992542.754455
UNITS FEET
IMAGECOLOR 255 255 255
PROJECTION
"init=epsg:102740"
END
IMAGETYPE PNG24
SHAPEPATH '/path/to/data/'
STATUS ON
SYMBOLSET "examples.sym"
FONTSET '/usr/share/fonts/fonts.list'
CONFIG "MS_ERRORFILE" "/path/to/cad.log"
WEB
TEMPLATE "mapserver.html"
IMAGEPATH
"/var/www/vhosts/snoogems.com/subdomains/maps/httpdocs/temp/"
IMAGEURL "/temp/"
METADATA
"wms_title" "CAD Search"
"wfs_title" "CAD Search"
"wms_srs" "EPSG:102740 EPSG:4326"
"wfs_srs" "EPSG:102740 EPSG:4326"
"wms_onlineresource" "http://url.com/cgi-bin/mapserv?map=/path/to/cads"
"wfs_onlineresource" "http://url.com/cgi-bin/mapserv?map=/path/to/cads"
"wms_feature_info_mime_type" "text/html"
END
END
QUERYMAP
STATUS ON
STYLE HILITE
COLOR 255 255 0
END
LAYER
NAME 'bldg_query'
TYPE QUERY
STATUS ON
DEBUG 3
TEMPLATE bldgGetFeatureInfo.html
HEADER bldgGetFeatureInfo_header.html
FOOTER bldgGetFeatureInfo_footer.html
PROCESSING "CLOSE_CONNECTION=DEFER"
DUMP TRUE
MAXSCALEDENOM 10000
CONNECTIONTYPE POSTGIS
CONNECTION "dbname=cad1 user=tedkspradley password=05gusher
host=localhost port=5432"
DATA "the_geom from (select b.the_geom AS the_geom, b.gid AS gid,
b.hcad_num AS hcad_num FROM parcels b) as foo using unique gid using
srid=-1"
JOIN
NAME "building_components"
CONNECTION "dbname=cad1 user=usr password=pw host=localhost port=5432"
CONNECTIONTYPE ogr
TABLE "building_components"
FROM "hcad_num"
TO "hcad_acct"
TYPE ONE-TO-MANY
TEMPLATE bldgGetFeatureInfo_join.html
END
PROJECTION
"init=epsg:102740"
END
METADATA
"wms_title" "Building Components Query Layer"
"wfs_title" "Building Components Query Layer"
"wms_srs" "epsg:102740 epsg:4326"
"gml_include_items" "all"
"wms_include_items" "all"
"gml_featureid" "ogc_fid"
"qstring_validation_pattern" '.'
END
END # End layer 'bldg_query'
Thank you,
Ted S
MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Linux/Fedora7
View this message in context: http://n2.nabble.com/5-6-1-GetFeatureInfo-template-processing-tp4393728p4393728.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
