[mapserver-users] Newbee, hello world problem! It used to work
on my old system!
Ted Spradley
tspradley at snoogems.com
Thu Jan 14 11:59:29 EST 2010
Insert the 'magic string' <!-- Mapserver Template --> at the beginning of
all of your html templates and
// Mapserver Template at the beginning of any javascript templates you have.
Gazz1982 wrote:
> this error:msLoadMap(): Unknown identifier. First token must be MAP, this
> doesn't look like a mapfile. seems to have fixed itself by adding the MAP
> tag but now it has a problem with the html file!
> Content-type: text/html isValidTemplate(): Web application error. Missing
> magic string, /var/www/htdocs/hello.html doesn't look like a MapServer
> template.
Thank you,
Ted S
MapServer version 5.6.1 OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP
OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=ICONV
SUPPORTS=WMS_SERVER SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER
SUPPORTS=WFS_CLIENT SUPPORTS=WCS_SERVER SUPPORTS=FASTCGI SUPPORTS=THREADS
INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDAL INPUT=SHAPEFILE
Linux/Fedora7
View this message in context: http://n2.nabble.com/Newbee-hello-world-problem-It-used-to-work-on-my-old-system-tp4348856p4393840.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
