[mapserver-users] resolution
Alan Boudreault
aboudreault at mapgears.com
Mon Jan 25 10:34:14 EST 2010
Hi
Set the DEFRESOLUTION to 72 (I assume all your mapfile settings are for a
72dpi image) , change the RESOLUTION to 300. Change your map size if you want
a big 300dpi image.
It is possible that the image header doesn't contain the DPI information. This
can easily be modified with a graphic program like "The GIMP".
Alan
On January 25, 2010 10:00:52 am Valeria Muñoz wrote:
> Hi
> I need to produce a 300dpi image for printing, i defined a RESOLUTION
> 300 in the mapfile , but nothing happens , still in 72 dpi ... can you help
> me please?
> mapfile
> MAP
> NAME neonline_mapa
> RESOLUTION 300
> SIZE 400 400
> UNITS dd
> SHAPEPATH "c:/ms4w/Apache/htdocs/test_mapfile/dataB2/"
> EXTENT -112.888238 -57.06133625 -7.419488000000001 13.25116375
> FONTSET "c:/ms4w/Apache/htdocs/test_map_dis/fonts/fonts.txt"
> PROJECTION
> 'proj=longlat'
> 'ellps=WGS84'
> 'datum=WGS84'
> 'no_defs'
> END
> IMAGECOLOR 122 206 232
> OUTPUTFORMAT
> NAME png
> DRIVER "AGG/PNG"
> MIMETYPE 'image/png'
> IMAGEMODE RGB #RGBA transparente
> EXTENSION "png"
> FORMATOPTION "TRANSPARENT=ON"
> FORMATOPTION "INTERLACE=ON"
> FORMATOPTION "QUANTIZE_COLORS=256"
> END
> # Legend
> LEGEND
> IMAGECOLOR 255 255 255
> STATUS ON
> KEYSIZE 18 12
> LABEL
> TYPE BITMAP
> SIZE MEDIUM
> COLOR 0 0 89
> END
> END
Alan Boudreault
Mapgears
http://www.mapgears.com
