[mapserver-users] Problems with mapserver wrapper script [SOLVED]
David Alda Fernandez de Lezea
dalda at ikt.es
Fri Jul 2 03:07:22 EDT 2010
Jukka,
> Another possibility is in one unnecessary "=" sign. Try SetEnvIf Request_URI "/cgi-bin/wms_dgis.exe"
Tha was the mistake (Aaaaaaargh!!! What a silly a thing!!!). I removed "=" and worked perfectly.
Thanks!!!!
Un saludo,
David Alda Fernández de Lezea
Lurralde eta Biodibertsitate Saila / Dpto. de Territorio y Biodiversidad
IKT
Granja Modelo s/n · 01192 · Arkaute (Araba)
Tlfnos.: 945-00-32-95 Fax: 945-00.32.90
email: dalda at ikt.es web: www.ikt.es
-----Mensaje original-----
De: Rahkonen Jukka [mailto:Jukka.Rahkonen at mmmtike.fi]
Enviado el: jueves, 01 de julio de 2010 14:00
Para: David Alda Fernandez de Lezea; mapserver-users at lists.osgeo.org
Asunto: Re: [mapserver-users] Problems with mapserver wrapper script
I do not see anything wrong in it. It should work and perhaps give you another error as I am getting from Mapserver 5.2.1
msWMSDispatch(): WMS server error. Incomplete WMS request: VERSION parameter
I would have a try by including the drive letter in the mapfile path and restarting Apache, but I fear it does not help. Another possibility is in one unnecessary "=" sign. Try SetEnvIf Request_URI "/cgi-bin/wms_dgis.exe"
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta David Alda
> Fernandez de Lezea
> Lähetetty: 1. heinäkuuta 2010 14:37
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: [mapserver-users] Problems with mapserver wrapper script
> Hi list,
> I'm facing a small problem. I've copied mapserv.exe to a new file
> called wms_dgis.exe, I added to httpd.conf the following line
> SetEnvIf Request_URI ="/cgi-bin/wms_dgis.exe"
> MS_MAPFILE=/ms4w/Apache/htdocs/MFD/wms_dgis.map
> I also changed the onlineresource value of the mapfile to
> "wms_onlineresource"
> "http://192.168.1.65/cgi-bin/wms_dgis.exe?"
> When I type in the web browser the url
> http://192.168.1.65/cgi-bin/wms_dgis.exe?, I get:
> No query information to decode. QUERY_STRING is set, but empty.
> So I think I'm on the right way, but when I make a getCapabilities
> request like:
> http://192.168.1.65/cgi-bin/wms_dgis.exe?SERVICE=WMS&REQUEST=G
etCapabilities
> I get:
> loadMap(): Web application error. CGI variable "map" is not set.
> I've looked into Apache's access.log but I don't see anything odd.
> MS4W package
> Mapserver 5.6.1
> Win XP
> Am I doing something wrong??
> Un saludo,
> Biodiversidad
> IKT
