[mapserver-users] Java MapScript and Tomcat6 Hanging
Gilbertson, Paul
paulbe at ceh.ac.uk
Wed Jul 21 10:41:27 EDT 2010
Good folks,
I am somewhat new to MapServer and MapScript, and I'm trying to do a few experiments with Java Mapscript in order to scope out MapServer's feasibility for a large project.
I've downloaded and installed MS4W 3.0 beta 11, and Netbeans 6.9 with Tomcat 6.0.29 in order to test out Java Mapscript. I created a most basic servlet to serve up simple map tiles, and it works for serial requests. When I try to serve two requests at the same time Tomcat hangs hard.
My map file and Java classes are below:
MAP
IMAGETYPE PNG24
NAME "nbndemo"
STATUS ON
EXTENT -12.5 12.5 700000 1300012.5
SIZE 800 800
IMAGECOLOR 226 245 255
CONFIG "MS_ERRORFILE" "/ms4w/apps/nbndemo/error.txt"
DEBUG 5
PROJECTION
"init=epsg:27700"
END
LAYER
NAME os250k
STATUS ON
TILEINDEX "/OSRasterTiles/os_250k/os250k_tindex_srs.shp"
TILEITEM "Location"
TYPE RASTER
OFFSITE 71 74 65
PROJECTION
"init=epsg:27700"
END
END
END
public class SPRewriter {
public synchronized void doLogic(HttpServletRequest request, HttpServletResponse response) throws Exception
ServletOutputStream out = response.getOutputStream();
edu.umn.gis.mapscript.mapObj mo = new mapObj("/ms4w/apps/nbndemo/mapfiles/test.map");
imageObj image = mo.draw();
response.setContentType(image.getFormat().getMimetype());
out.write(image.getBytes());
image.delete();
mo.delete();
protected void processRequest(HttpServletRequest request, HttpServletResponse response) throws ServletException, IOException {
try {
SPRewriter spr = new SPRewriter();
spr.doLogic(request, response);
} catch (Exception e) {
e.printStackTrace();
Any thoughts why this would hang the moment I try to run parallel requests?
Regards,
Paul Gilbertson
This message (and any attachments) is for the recipient only. NERC
is subject to the Freedom of Information Act 2000 and the contents
of this email and any reply you make may be disclosed by NERC unless
it is exempt from release under the Act. Any material supplied to
NERC may be stored in an electronic records management system.
