[mapserver-users] mapserver >= 5.6 and querys via php-mapscript
Lime, Steve D (DNR)
Steve.Lime at state.mn.us
Thu Jun 10 13:54:29 EDT 2010
The concept changed in 5.6 to support improved query performance, especially for RDBMS data sources. It's been a bit of
a cluster though and interpretation of $result->shapeindex varies by 5.6.x version and driver. We'll get this straightened
out and simplified in 6.0. Addressing 5.6.3 only:
- shapeindex should hold the global record index for a shape
- tileindex should hold the result set record index for a shape (for RDBMS data sources, e.g. Oracle and PostGIS only)
There still may be inconsistencies with OGR-fronted RDBMS sources.
Steve
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Sven Schroeter
Sent: Thursday, June 10, 2010 10:27 AM
To: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] mapserver >= 5.6 and querys via php-mapscript
Hi Daniel,
> I don't think there is any way to get the "real" shapeindex unless you
> have an id field in the data itself. You could file a ticket about this,
> but for some data sources, such as Postgis, Oracle Spatial, and many OGR
> ones, there is no concept of absolute record id, so if something was
> added, it would very likely work only for shapefiles
in the older ms versions I got with $result->shapeindex an absolute record
id for all data sources (postgis, OGR, shapefiles).
what ids were used before by default e.g. for postgis data?
why this concept has changed in the new version 5.6?
Thanx
Sven
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100610/fa0a8571/attachment.html
