[mapserver-users] mapserver >= 5.6 and querys via php-mapscript
Cristiano Sumariva
sumariva at gmail.com
Fri Jun 11 11:06:41 EDT 2010
If I remember well the loader script shp2pgsql create the unique attribute
called gid. And that gid I supose be the record id or record position from
the shape source file.
So if you need a map between file position and database record returned read
the attribute 'gid' from that shape record.
I do not know if still done on recent versions of loader.
2010/6/10 Lime, Steve D (DNR) <Steve.Lime at state.mn.us>
> The concept changed in 5.6 to support improved query performance,
> especially for RDBMS data sources. It’s been a bit of
> a cluster though and interpretation of $result->shapeindex varies by 5.6.x
> version and driver. We’ll get this straightened
> out and simplified in 6.0. Addressing 5.6.3 only:
> - shapeindex should hold the global record index for a shape
> - tileindex should hold the result set record index for a shape
> (for RDBMS data sources, e.g. Oracle and PostGIS only)
> There still may be inconsistencies with OGR-fronted RDBMS sources.
> Steve
> *From:* mapserver-users-bounces at lists.osgeo.org [mailto:
> mapserver-users-bounces at lists.osgeo.org] *On Behalf Of *Sven Schroeter
> *Sent:* Thursday, June 10, 2010 10:27 AM
> *To:* mapserver-users at lists.osgeo.org
> *Subject:* Re: [mapserver-users] mapserver >= 5.6 and querys via
> php-mapscript
> Hi Daniel,
> > I don't think there is any way to get the "real" shapeindex unless you
> > have an id field in the data itself. You could file a ticket about this,
> > but for some data sources, such as Postgis, Oracle Spatial, and many OGR
> > ones, there is no concept of absolute record id, so if something was
> > added, it would very likely work only for shapefiles
> in the older ms versions I got with $result->shapeindex an absolute record
> id for all data sources (postgis, OGR, shapefiles).
> what ids were used before by default e.g. for postgis data?
> why this concept has changed in the new version 5.6?
> Thanx
> Sven
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100611/c8800476/attachment.html
