[mapserver-users] error with getfeauture info for postgis tile index
Lassche, M.R (Ronnie)
mlassche at feweb.vu.nl
Tue Jun 29 14:55:33 EDT 2010
Hi All,
I have a tileindex which is based on a postgis layer and everything works well.
I've put the 2 layers in one group in order to be able to get information from the index layer available for the users. When I use a shape file as an index this works fine. But when I use a postgis layer as index the following error occurs.
==error==
msShapefileOpen(): Unable to access file. (/mapserver/www/cgi-bin/maps/_tmk-index) msShapefileOpen(): Unable to access file. (/mapserver/www/cgi-bin/maps/_tmk-index) msShapefileOpen(): Unable to access file. (/mapserver/www/cgi-bin/maps/_tmk-index) msShapefileOpen(): Unable to access file. (/mapserver/www/cgi-bin/maps/_tmk-index)
It seems mapserver expects a shapefile and can not handle the postgis index layer for the getfeatureinfo.
Does someone has any idea what can be wrong?
Thanks in advance,
Ronnie
====part of the map file==
LAYER
GROUP "Topographische_en_militaire_kaart"
NAME "_tmk-index"
METADATA
WMS_TITLE "Topographische_en_militaire_kaart-index"
WMS_ABSTRACT "Topographische en militaire kaart-index"
WMS_NAME "Topographische_en_militaire_kaart-index"
WMS_SRS "EPSG:4326 EPSG:900913 EPSG:3785 EPSG:28992"
gml_include_items "location"
WMS_FEATURE_INFO_MIME_TYPE "text/html"
END
EXTENT 10000 305000 280000 619000
PROJECTION
"init=epsg:28992"
END
CONNECTION "user=postgres password=P0stG!s dbname=gisdb host=localhost port=5432"
CONNECTIONTYPE postgis
DATA "geom from (SELECT kaartbladid ,location,geom FROM vw_bladgrenzen_rd WHERE serie_id = 2) as grens USING UNIQUE kaartbladid "
STATUS ON
DUMP TRUE
TEMPLATE "/mapserver/www/infotemplates/tmk_scan_leeg.html"
TYPE POLYGON
UNITS METERS
MAXSCALE 8000000
MINSCALE 500
END
LAYER
NAME "tmk-scan"
METADATA
WMS_TITLE "Topographische_en_militaire_kaart-scan"
WMS_ABSTRACT "Topographische en militaire kaart-scan"
WMS_NAME "nsw-landgoederen"
gml_include_items "all"
END
PROJECTION
"init=epsg:28992"
END
TILEINDEX "_tmk-index"
TILEITEM "location"
STATUS ON
DUMP TRUE
TYPE RASTER
UNITS METERS
MAXSCALE 8000000
MINSCALE 500
PROCESSING "BANDS=1,2,3"
OFFSITE 0 0 0
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100629/c02a0174/attachment.html
