[mapserver-users] line width unit ignored after mapserver upgrade
Oliver Christen
oliver.christen at camptocamp.com
Mon Mar 1 04:58:30 EST 2010
Hi Bart
that was it!
my map has RESOLUTION 254
so adding a DEFRESOLUTION 254 solved the problem
thank you very much
best regards
Oliver
----- Original Message -----
is your MAP->RESOLUTION different from 72? If so, set DEFRESOLUTION to your
value as well.
Best regards,
Bart
On Mar 1, 2010, at 9:32 AM, Oliver Christen wrote:
> hello
> I recently upgraded mapserver from 5.4 to 5.6.1 and all my line style are
> computed in meter (I believe) instead of pixel.
> here is the result im getting:
> http://dev.camptocamp.com/~ochriste/wms_line.png
> here is my layer definition:
> LAYER
> NAME "SitPrProjetConsLine"
> GROUP "GrpConstruction"
> METADATA
> "wms_title" "SitPrProjetConsLine"
> END
> TYPE LINE
> DATA SIT_PR_Projet_cons_line
> STATUS ON
> DEBUG 5
> MAXSCALE 10001
> SIZEUNITS pixels
> CLASS
> STYLE
> COLOR 0 0 255
> WIDTH 1
> MAXWIDTH 1
> MINWIDTH 1
> END
> END
> END
> here is the query I do:
> ?LAYERS=SitPrProjetConsLine&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A21781&BBOX=506263.99910144,143335.99917056,506391.99903232,143463.99910144&WIDTH=256&HEIGHT=256
> I want a line width of 1px
> What am I doing wrong ?
> thanks in advance
> Oliver
> mapserver-users at lists.osgeo.org
