[mapserver-users] line width unit ignored after mapserver upgrade
thomas bonfort
thomas.bonfort at gmail.com
Mon Mar 1 05:09:14 EST 2010
if you're aiming for webmapping and screen display, you should
probably not be setting those to a value other than the default value.
resolution is used for high-res print output, eg passing from
http://server/mapserv/?[....]width=300&height=300
to
http://server/mapserv/?[....]map_resolution=288&width=1200&height=1200
to get a higher resolution image, but without affecting the actual
styles being used.
thomas
On Mon, Mar 1, 2010 at 10:58, Oliver Christen
<oliver.christen at camptocamp.com> wrote:
> Hi Bart
> that was it!
> my map has RESOLUTION 254
> so adding a DEFRESOLUTION 254 solved the problem
> thank you very much
> best regards
> Oliver
> ----- Original Message -----
> Hi,
> is your MAP->RESOLUTION different from 72? If so, set DEFRESOLUTION to your
> value as well.
> Best regards,
> Bart
> On Mar 1, 2010, at 9:32 AM, Oliver Christen wrote:
>> hello
>> I recently upgraded mapserver from 5.4 to 5.6.1 and all my line style are
>> computed in meter (I believe) instead of pixel.
>> here is the result im getting:
>> http://dev.camptocamp.com/~ochriste/wms_line.png
>> here is my layer definition:
>> LAYER
>> NAME "SitPrProjetConsLine"
>> GROUP "GrpConstruction"
>> METADATA
>> "wms_title" "SitPrProjetConsLine"
>> END
>> TYPE LINE
>> DATA SIT_PR_Projet_cons_line
>> STATUS ON
>> DEBUG 5
>> MAXSCALE 10001
>> SIZEUNITS pixels
>> CLASS
>> STYLE
>> COLOR 0 0 255
>> WIDTH 1
>> MAXWIDTH 1
>> MINWIDTH 1
>> END
>> END
>> END
>> here is the query I do:
>> ?LAYERS=SitPrProjetConsLine&FORMAT=image%2Fpng&SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&STYLES=&EXCEPTIONS=application%2Fvnd.ogc.se_inimage&SRS=EPSG%3A21781&BBOX=506263.99910144,143335.99917056,506391.99903232,143463.99910144&WIDTH=256&HEIGHT=256
>> I want a line width of 1px
>> What am I doing wrong ?
>> thanks in advance
>> Oliver
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
