[mapserver-users] OSM2pgsql, latlong, OpenStreetMap data, uDig
= weird projection
Thomasch
thomaschx at gmx.de
Mon Mar 15 10:01:18 EDT 2010
there is an HowTo: http://trac.osgeo.org/mapserver/wiki/RenderingOsmData
In your Mapfile, you have to state the Projection like the following:
Map
PROJECTION
"init=epsg:4326"
END
LAYER
METADATA
"WMS_TITLE" "Parks"
END
CLASSITEM "leisure"
CONNECTION "user=xxx password=xxx dbname=xxx host=localhost port=5432"
CONNECTIONTYPE POSTGIS
DATA "way FROM planet_osm_polygon using unique gid using srid=900913 "
NAME "OSM_Parks"
STATUS ON
TOLERANCE 0
TYPE POLYGON
LabelItem "name"
CLASS
NAME "Parks"
EXPRESSION "park"
STYLE
COLOR 89 150 89
END
LABEL
COLOR 0 0 0
FONT vera_sans
TYPE truetype
SIZE 8
POSITION AUTO
MINDISTANCE 0
PARTIALS FALSE
OUTLINECOLOR 255 255 255
END
END
PROJECTION
"init=epsg:900913"
END
END
END
Maybe that helps.
Thomasch
