[mapserver-users] QGIS MapServer Export error
Scarlett Jiang
jiangtianscarlett at hotmail.com
Fri Mar 19 11:53:06 EDT 2010
Dear All,
I have encountered a problem while trying to export map files from QGIS using "MapServer Export" plugin.
The mapfile that I got back cannot be viewed using shp2img utilities. I got an error saying : "msLoadMap(): Regular expression error. MS_DEFAULT_MAPFILE_PATTERN validation failed. msEvalRegex(): Regular expression error. String failed expression test. " In addition, when I tried displaying the mapfile obtained from QGIS through openlayers, I got blank gray images. I have also tried removing all the layer info in the mapfile, but still got the same error.
However, if I write a mapfile by myself, then the shp2img utility works fine. Is there any problem with the QGIS MapServer Export plugin? Or have I done anything wrong?
Thanks in advance!
Scarlett
_________________________________________________________________
Hotmail: Trusted email with Microsoft¡¯s powerful SPAM protection.
https://signup.live.com/signup.aspx?id=60969
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20100319/432677fd/attachment.html
