[mapserver-users] Cannot get my layer to render via WMS...
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Mar 24 09:56:25 EDT 2010
There is something odd here but I really can't figure out what. One thing is that you do not need EXTENT at LAYER level as you do now. I wonder if it is related to that GetCapabilities gives odd extents to the layer "test" as can be seen:
<Layer queryable="0" opaque="0" cascaded="0">
> > <Name>test</Name>
> > <Title>TestLayer</Title>
> > <SRS>EPSG:4326</SRS>
> > <LatLonBoundingBox minx="-3.40282e+038" miny="-3.40282e+038"
> > maxx="3.40282e+038" maxy="3.40282e+038" />
> > <BoundingBox SRS="EPSG:4326"
Strange extents for EPSG:4326 projection, aren't they? What is "geog" used in the DATA line doing?
DATA "geog FROM test USING SRID=4326 USING UNIQUE gid"
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta Jeff McKenna
> Lähetetty: 24. maaliskuuta 2010 16:28
> Vastaanottaja: mapserver-users at lists.osgeo.org
> Aihe: Re: [mapserver-users] Cannot get my layer to render via WMS...
> mapper99 wrote:
> > Here is a map file I have:
> > MAP
> > NAME "WMSTEST"
> > EXTENT -91.409324 40.696301 -90.942253 41.074178
> > SIZE 800 600
> > IMAGECOLOR 255 255 255
> > PROJECTION
> > "init=epsg:4326"
> > END
> > WEB
> > IMAGEPATH "/ms4w/tmp/ms_tmp/"
> > IMAGEURL "/ms_tmp/"
> > METADATA
> > "wms_title" "WMS Test Server" ##required
> > "wms_onlineresource"
> "http://localhost:8080/cgi-bin/mapserv.exe?map=testwms.map&"
> ##required
> > "wms_srs" "EPSG:4326" ##recommended
> > END
> > END
> > LAYER
> > NAME "test"
> > METADATA
> > "wms_title" "TestLayer" ##required
> > END
> > PROJECTION
> > "init=epsg:4326" ##recommended
> > END
> > STATUS ON
> > TYPE POLYGON
> > CONNECTIONTYPE POSTGIS
> > CONNECTION "host=127.0.0.1 port=5432 dbname=MarkGIS
> user=postgres
> > password=theguy"
> > CLASSITEM 'cousubfp00'
> > CLASS
> > NAME 'default'
> > EXPRESSION ''
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 106 72 44
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 90207'
> > EXPRESSION '90207'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 130 86 84
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 90401'
> > EXPRESSION '90401'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 160 64 74
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 90813'
> > EXPRESSION '90813'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 137 230 122
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 90887'
> > EXPRESSION '90887'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 84 173 118
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 90888'
> > EXPRESSION '90888'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 149 106 236
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 91347'
> > EXPRESSION '91347'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 31 170 38
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 91401'
> > EXPRESSION '91401'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 64 29 27
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 92010'
> > EXPRESSION '92010'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 176 211 126
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 92112'
> > EXPRESSION '92112'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 116 167 107
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 92906'
> > EXPRESSION '92906'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 164 26 212
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 92924'
> > EXPRESSION '92924'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 94 224 133
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 93390'
> > EXPRESSION '93390'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 246 101 186
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 94080'
> > EXPRESSION '94080'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 161 96 208
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 94203'
> > EXPRESSION '94203'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 218 17 190
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 94488'
> > EXPRESSION '94488'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 93 61 209
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 94658'
> > EXPRESSION '94658'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 200 70 144
> > END
> > END
> > CLASS
> > NAME 'cousubfp00 = 94803'
> > EXPRESSION '94803'
> > STYLE
> > SYMBOL 0
> > OUTLINECOLOR 0 0 0
> > COLOR 45 32 194
> > END
> > END
> > CLASS
> > OUTLINECOLOR 32 32 32
> > END
> > END
> > END
> > If I use this URL:
> http://localhost:8080/cgi-bin/mapserv.exe?map=/ms4w/apps/tutor
ial/mapfiles/testwms.map&layer=test&mode=map
> > The map draws fine. If I try and consume this map via a
> WMS client like
> > QGIS, the data does not draw. GetCapabilities appears to be fine:
ial/mapfiles/testwms.map&SERVICE=WMS&VERSION=1.1.1> &REQUEST=GetCapabilities
> > returns:
> > <?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
> > <!DOCTYPE WMT_MS_Capabilities SYSTEM
> > "http://schemas.opengis.net/wms/1.1.1/WMS_MS_Capabilities.dtd"
> > <!ELEMENT VendorSpecificCapabilities EMPTY>
> > ]> <!-- end of DOCTYPE declaration -->
> > <WMT_MS_Capabilities version="1.1.1">
> > <!-- MapServer version 5.2.1 OUTPUT=GIF OUTPUT=PNG
> OUTPUT=JPEG OUTPUT=WBMP
> > OUTPUT=PDF OUTPUT=SWF OUTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG
> > SUPPORTS=FREETYPE SUPPORTS=ICONV SUPPORTS=FRIBIDI
> SUPPORTS=WMS_SERVER
> > SUPPORTS=WMS_CLIENT SUPPORTS=WFS_SERVER SUPPORTS=WFS_CLIENT
> > SUPPORTS=WCS_SERVER SUPPORTS=SOS_SERVER SUPPORTS=FASTCGI
> SUPPORTS=THREADS
> > SUPPORTS=GEOS SUPPORTS=RGBA_PNG INPUT=JPEG INPUT=POSTGIS INPUT=OGR
> > INPUT=GDAL INPUT=SHAPEFILE -->
> > <Service>
> > <Name>OGC:WMS</Name>
> > <Title>WMS Test Server</Title>
> > <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink"
> xlink:href="http://localhost:8080/cgi-bin/mapserv.exe?map=test
wms.map&"/>
> > <ContactInformation>
> > </ContactInformation>
> > </Service>
> > <Capability>
> > <Request>
> > <GetCapabilities>
> > <Format>application/vnd.ogc.wms_xml</Format>
> > <DCPType>
> > <HTTP>
> > <Get><OnlineResource
wms.map&"/></Get>
> > <Post><OnlineResource
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </GetCapabilities>
> > <GetMap>
> > <Format>image/gif</Format>
> > <Format>image/png</Format>
> > <Format>image/png; mode=24bit</Format>
> > <Format>image/jpeg</Format>
> > <Format>image/vnd.wap.wbmp</Format>
> > <Format>image/tiff</Format>
> > <Format>image/svg+xml</Format>
> > <DCPType>
> > <HTTP>
wms.map&"/></Get>
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </GetMap>
> > <GetFeatureInfo>
> > <Format>text/plain</Format>
> > <Format>application/vnd.ogc.gml</Format>
> > <DCPType>
> > <HTTP>
wms.map&"/></Get>
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </GetFeatureInfo>
> > <DescribeLayer>
> > <Format>text/xml</Format>
> > <DCPType>
> > <HTTP>
wms.map&"/></Get>
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </DescribeLayer>
> > <GetLegendGraphic>
> > <DCPType>
> > <HTTP>
wms.map&"/></Get>
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </GetLegendGraphic>
> > <GetStyles>
> > <DCPType>
> > <HTTP>
wms.map&"/></Get>
wms.map&"/></Post>
> > </HTTP>
> > </DCPType>
> > </GetStyles>
> > </Request>
> > <Exception>
> > <Format>application/vnd.ogc.se_xml</Format>
> > <Format>application/vnd.ogc.se_inimage</Format>
> > <Format>application/vnd.ogc.se_blank</Format>
> > </Exception>
> > <VendorSpecificCapabilities />
> > <UserDefinedSymbolization SupportSLD="1" UserLayer="0"
> UserStyle="1"
> > RemoteWFS="0"/>
> > <Layer>
> > <Name>WMSTEST</Name>
> > <LatLonBoundingBox minx="-91.4093" miny="40.6963"
> maxx="-90.9423"
> > maxy="41.0742" />
> > minx="-91.4093" miny="40.6963" maxx="-90.9423"
> > maxy="41.0742" />
> > <Name>test</Name>
> > <Style>
> > <Name>default</Name>
> > <Title>default</Title>
> > <LegendURL width="161" height="329">
> > <OnlineResource
> > xlink:type="simple"
wms.map&version=1.1.1> &service=WMS&request=GetLegendGraphic&layer=test&a
> mp;format=image/png&STYLE=default"/>
> > </LegendURL>
> > </Style>
> > </Layer>
> > </Layer>
> > </Capability>
> > </WMT_MS_Capabilities>
> > But nothing draws in the map? What am I doing wrong here?
> I think the step you are missing is to verify that your
> GetMap request
> works. (manually generate a GetMap URL and try that in a
> browser, like
> you did for your GetCapabilities request). Once you verify that that
> manual GetMap works, then you should try to access your WMS layers in
> various WMS clients (like QGIS).
> -jeff
> Jeff McKenna
> MapServer Consulting and Training Services
> http://www.gatewaygeomatics.com/
