[mapserver-users] RE: Measure tool?
Ludwig Kniprath
ludwig at kni-online.de
Fri Nov 12 14:14:32 EST 2010
Hi Bob,
we use clientside javascript-functions. They both need an array of
points ("digi_points") with real-world-coordiantes (properties "pointX"
and "pointY") as input-parameter.
This array is filled by clicks on the map, the click-coordiantes
(pixel-distance from the click-point to the upper left corner of the
map-grafic) ar calculated to real-wolrd coordinates with the upper left
corner-coordinates and the cellsize of the map, these two parameters are
returned to the browser together with the grafic by php-mapscript.
function get_digi_points_length(digi_points) {
var calculated_length = 0;
for ( var i = 0; i < (digi_points.length - 1); i++) {
var from_point = digi_points[i];
var to_point = digi_points[i + 1];
var delta_x = to_point.pointX - from_point.pointX;
var delta_y = to_point.pointY - from_point.pointY;
var delta_length = Math.sqrt(Math.pow(delta_x, 2) +
Math.pow(delta_y, 2));
calculated_length += delta_length;
return calculated_length;
//precheck the digi_points for closed ring: digi_points[0] ==
digi_points[digi_points.length - 1]
function get_digi_points_area(digi_points) {
var calculated_area = 0;
var delta_area = from_point.pointX * to_point.pointY -
to_point.pointX * from_point.pointY;
calculated_area += delta_area;
calculated_area *= 0.5;
// if digitized counter-clockwise the result is negative!
calculated_area = Math.abs(calculated_area);
return calculated_area;
Ludwig
