[mapserver-users] CGI wrapper scripts
David Hildebrand
David.Hildebrand at afsc.ca
Wed Nov 17 19:35:05 EST 2010
Thanks to those that helped. I now have a wrapper which not only hides
the 'map' parameter but also hides 'service' and 'version' (for
OGC-compliant queries). The PERL source is listed below. Feel free to
use it and send me feedback.
# A CGI wrapper for mapserv.exe to hide constant URL parameters for
OGC-compliant queries.
# The mapname, service and version are obtained from the name of this
file.
# mapenv - name of environment variable holding the full path name of
the MapServer map file
# defined in the http server configuration
# service - type of service (WMS, WFS or WCS)
# version - OGC version number with dots omitted (eg., 1.1.1 is shown
as 111)
# Original coding: David Hildebrand
November, 2010
use CGI;
use File::Spec;
my $query = CGI->new;
if ($query->request_method() !~ /GET/i) {die "Not a GET request\n";}
# Parse file name.
my (undef,undef,$fn) = File::Spec->splitpath($0);
my ($mapenv,$service,$version,undef) = split(/\./,$fn);
if (!exists($ENV{"\U$mapenv\E"})) {die "\U$mapenv\E environment variable
not set\n";}
if ($service !~ /\AWMS\Z|\AWFS\Z|\AWCS\Z/i) {die "\U$service\E not
supported\n";}
$version = substr($version,0,1) . '.' . substr($version,1,1) . '.' .
substr($version,2,1);
# Reset MAP, SERVICE and VERSION.
$query->delete('map','service','version');
$query->param(-name=>'map',-value=>$ENV{"\U$mapenv\E"});
$query->param(-name=>'service',-value=>"\U$service\E");
$query->param(-name=>'version',-value=>$version);
# Reconstruct CGI query.
my @elements = ();
foreach my $pname ($query->param()) {
my @values = $query->param($pname);
if (scalar(@values) > 1) {push @elements, "\U$pname=\E" .
join(',', at values);}
if (scalar(@values) == 1) {push @elements, "\U$pname=\E" .
$values[0];}
if (scalar(@values) == 0) {push @elements, "\U$pname=\E"}
# Invoke mapserv.exe and never return.
$ENV{QUERY_STRING} = join('&', at elements);
exec 'mapserv.exe';
exit;
David V. Hildebrand
Agriculture Financial Services Corporation
(403) 782-8239
www.afsc.ca <http://www.afsc.ca>
This communication is intended for the use of the recipient to which it
is addressed, and may contain confidential, personal and/or privileged
information. Please contact Agriculture Financial Services Corporation
immediately if you are not the intended recipient of this communication,
and do not copy, distribute, or take action relying on it. Any
communication received in error, or subsequent reply, should be deleted
or destroyed. Please consider the environment before printing this
email.
-----Original Message-----
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of David
Hildebrand
Sent: Wednesday, November 17, 2010 10:20 AM
To: mapserver-users at lists.osgeo.org
Subject: [mapserver-users] CGI wrapper scripts
The MapServer documentation has an example of CGI wrapper scripts for a
UNIX environment. Would there be an equivalent Windows form I could
use? I was thinking of using PERL.
David V. Hildebrand
(403) 782-8239
email.
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101117/f9a4f174/attachment-0001.html
