[mapserver-users] LABEL POSITION - Numeric or String from a
database
Donald Kerr
donald.kerr at dkerr.co.uk
Sun Nov 21 09:33:59 EST 2010
Tommaso,
There are already 30 classes, each with their own attributes, some of which
also come from the database (see example below). I don't think I can also
use CLASSITEM and two EXPRESSIONs.
LABELITEM textstring
CLASS
# Building
EXPRESSION ([featurecode] = 10020)
LABEL
TYPE truetype
FONT arial
SIZE [height]
POSITION cc
#POSITION [AnchorPositionTxt]
COLOR [oscolor]
ANTIALIAS TRUE
ANGLE [orientation]
FORCE TRUE
END # LABEL
END # CLASS
Regards,
Donald
-----Original Message-----
Sent: 21 November 2010 13:59
To: Donald Kerr
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] LABEL POSITION - Numeric or String from a
database
Hallo Donald,
you can define a layer with so many classes how are your possible label
positions and filter each class with the value of the attribute
"AnchorPositionTxt"
i.e:
LAYER
NAME "layer"
CLASSITEM "AnchorPositionTxt"
LABELITEM "name"
CLASS
EXPRESSION "ul"
LABEL
POSITION ul
END
END
CLASS
EXPRESSION "lr"
LABEL
POSITION lr
END
END
END
Cheers,
Tommaso
On Sun, 2010-11-21 at 10:21 +0000, Donald Kerr wrote:
Hi List,
I am trying to change a LABEL's POSITION by using an integer without
success.
As far as I can see, the LABEL's POSITION can be any one of the following
constants: enum MS_POSITIONS_ENUM {MS_UL=101, MS_LR, MS_UR, MS_LL, MS_CR,
MS_CL,
MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY , MS_FOLLOW};
I was assuming that I can replace UL with "101" i.e. instead of "POSITION
UL" I use "POSITION 101" but that doesn't work.
I have also tried replacing "POSITION UL" with text values from a database
i.e. "POSITION [AnchorPositionTxt]" where "AnchorPositionTxt" is a string
'UL' but, again, that doesn't work.
Is there a way to set this value dynamically from the database with either
numbers or strings ('UL', LR, etc...)?
Many thanks.
Regards,
Donald Kerr
mapserver-users mailing list
http://lists.osgeo.org/mailman/listinfo/mapserver-users
