[mapserver-users] LABEL POSITION - Numeric or String from a
database
tommaso
tommasodb at googlemail.com
Sun Nov 21 08:58:39 EST 2010
Hallo Donald,
you can define a layer with so many classes how are your possible label
positions and filter each class with the value of the attribute
"AnchorPositionTxt"
i.e:
LAYER
NAME "layer"
CLASSITEM "AnchorPositionTxt"
LABELITEM "name"
CLASS
EXPRESSION "ul"
LABEL
POSITION ul
END
END
CLASS
EXPRESSION "lr"
LABEL
POSITION lr
END
END
END
Cheers,
Tommaso
On Sun, 2010-11-21 at 10:21 +0000, Donald Kerr wrote:
> Hi List,
> I am trying to change a LABEL's POSITION by using an integer without
> success.
> As far as I can see, the LABEL's POSITION can be any one of the following
> constants: enum MS_POSITIONS_ENUM {MS_UL=101, MS_LR, MS_UR, MS_LL, MS_CR,
> MS_CL,
> MS_UC, MS_LC, MS_CC, MS_AUTO, MS_XY , MS_FOLLOW};
> I was assuming that I can replace UL with "101" i.e. instead of "POSITION
> UL" I use "POSITION 101" but that doesn't work.
> I have also tried replacing "POSITION UL" with text values from a database
> i.e. "POSITION [AnchorPositionTxt]" where "AnchorPositionTxt" is a string
> 'UL' but, again, that doesn't work.
> Is there a way to set this value dynamically from the database with either
> numbers or strings ('UL', LR, etc...)?
> Many thanks.
> Regards,
> Donald Kerr
> mapserver-users at lists.osgeo.org
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20101121/3e1bda1d/attachment.html
