[mapserver-users] WMS Request for a single point?
Robert Hicks
robhyx at gmail.com
Fri Oct 8 12:06:40 EDT 2010
Ok, that looks extremely promising. I'm going to go ahead and try it
on my local Mapserver.
On Fri, Oct 8, 2010 at 12:03 PM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
> the syntax for cgi commands has changed since then, you'd have to use
> something like
> &map.layer[site]=feature+points+582248.23+4841497.11+end+end
> or &map.layer[site].feature.points=582248.23+4841497.11
> (I cant remember what syntax is correct)
> regards,
> thomas
> On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
>> Hello all! Ok, this is probably a long shot but, is there a way to
>> request an image from Mapserver that is just a point? The idea is I
>> have another larger (reference) map image and I want to place a push
>> pin on top of it in a specified point. It has to be a WMS call so that
>> I can take the image and merge it with the other larger map into one
>> so that it can be put into a PDF. Any help would be appreciated.
>> Thanks!
>> web http://www.hyxspace.com
>> aim hyx1138
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
aim hyx1138
