[mapserver-users] WMS Request for a single point?
Fawcett, David (MPCA)
David.Fawcett at state.mn.us
Fri Oct 8 12:14:30 EDT 2010
This example works: http://localhost/cgi-bin/mapserv.exe?map=/ms4w/apps/offset.map&mode=map&map_layer[0]=FEATURE+POINTS+270000+696000+END+END
You can access your layer through the layer name or it's (zero-based) index.
The simple example layer is below with a simple circle symbol defined in the map file.
LAYER
NAME 'singlepoint'
TYPE point
STATUS DEFAULT
CLASS
STYLE
COLOR 255 0 0
SIZE 15
symbol "circle"
END
END
END
SYMBOL
NAME "circle"
TYPE ellipse
FILLED true
POINTS
1 1
END
END
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Robert Hicks
Sent: Friday, October 08, 2010 11:07 AM
To: thomas bonfort
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WMS Request for a single point?
Ok, that looks extremely promising. I'm going to go ahead and try it
on my local Mapserver.
On Fri, Oct 8, 2010 at 12:03 PM, thomas bonfort
<thomas.bonfort at gmail.com> wrote:
> have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
> the syntax for cgi commands has changed since then, you'd have to use
> something like
> &map.layer[site]=feature+points+582248.23+4841497.11+end+end
> or &map.layer[site].feature.points=582248.23+4841497.11
> (I cant remember what syntax is correct)
> regards,
> thomas
> On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
>> Hello all! Ok, this is probably a long shot but, is there a way to
>> request an image from Mapserver that is just a point? The idea is I
>> have another larger (reference) map image and I want to place a push
>> pin on top of it in a specified point. It has to be a WMS call so that
>> I can take the image and merge it with the other larger map into one
>> so that it can be put into a PDF. Any help would be appreciated.
>> Thanks!
>> web http://www.hyxspace.com
>> aim hyx1138
>> mapserver-users mailing list
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
aim hyx1138
