[mapserver-users] WMS Request for a single point?
thomas bonfort
thomas.bonfort at gmail.com
Fri Oct 8 12:08:13 EDT 2010
actually, this is documented here:
http://mapserver.org/cgi/controls.html -> Changing map file parameters
via a form or a URL
thomas
On Fri, Oct 8, 2010 at 18:06, Robert Hicks <robhyx at gmail.com> wrote:
> Ok, that looks extremely promising. I'm going to go ahead and try it
> on my local Mapserver.
> On Fri, Oct 8, 2010 at 12:03 PM, thomas bonfort
> <thomas.bonfort at gmail.com> wrote:
>> have a look at http://www.mail-archive.com/mapserver-users@lists.umn.edu/msg05881.html
>> the syntax for cgi commands has changed since then, you'd have to use
>> something like
>> &map.layer[site]=feature+points+582248.23+4841497.11+end+end
>> or &map.layer[site].feature.points=582248.23+4841497.11
>> (I cant remember what syntax is correct)
>> regards,
>> thomas
>> On Fri, Oct 8, 2010 at 17:10, Robert Hicks <robhyx at gmail.com> wrote:
>>> Hello all! Ok, this is probably a long shot but, is there a way to
>>> request an image from Mapserver that is just a point? The idea is I
>>> have another larger (reference) map image and I want to place a push
>>> pin on top of it in a specified point. It has to be a WMS call so that
>>> I can take the image and merge it with the other larger map into one
>>> so that it can be put into a PDF. Any help would be appreciated.
>>> Thanks!
>>> web http://www.hyxspace.com
>>> aim hyx1138
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> aim hyx1138
