[mapserver-users] Trouble shooting SLD?
K ken at sandnarrows.com
Tue Oct 19 17:27:14 PDT 2010
Do you mean the part about using GetStyles to get a SLD blurb from
Mapserver? I did try that originally, well I used PHP Mapscript to do
it. On the odd chance that GetStyles does something different I just did
a GetStyles request, changed the color and nothing else.
Still not working.
Ken
On 19/10/2010 7:32 PM, Jeff McKenna wrote:
> Hi Ken,
> See Assefa's last message to you, he made some great points. In fact I
> hit many of the points that Assefa mentioned when fixing those
> demo.mapserver.org examples.
> -jeff
> On 10-10-19 5:44 PM, K wrote:
>> Thanks again for your assistance.
>> The SLD file I was using was from the mapserver repository that Jeff
>> posted earlier in the thread. I went ahead and edited it and removed all
>> the differing bits from yours. No change, still not reading the SLD file.
>> I then decided to create a line file, in case the issue was polygons,
>> and use the SLD file you posted, with the only change being the name,
>> still not working.
>> I went through and changed all the names to be different, then tried
>> matching the SLD name with different parts in the odd hope it would
>> work, again no luck.
>> No matter what I do it seems the SLD is being ignored.
>> Ken
>> On 19/10/2010 3:52 AM, Rahkonen Jukka wrote:
>>> Hi,
>>> I have never made a single SLD file myself, just edited something
>>> working that I have found so unfortunately I fear I cannot give very
>>> good advice. I did, however, compare something that works for me and
>>> your SLD file and these are the differences:
>>> My first line has more elements:
>>> <StyledLayerDescriptor version="1.0.0"
>>> xmlns="http://www.opengis.net/sld"
>>> xmlns:gml="http://www.opengis.net/gml"
>>> xmlns:ogc="http://www.opengis.net/ogc"
>>> xmlns:xlink="http://www.w3.org/1999/xlink"
>>> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
>>> xsi:schemaLocation="http://www.opengis.net/sld
>>> http://schemas.opengis.net/sld/1.0.0/StyledLayerDescriptor.xsd">
>>> You have Title, I don't. Hard to believe this is critical, though
>>> <Title>Communities</Title>
>>> Then you are giving the geometry element as
>>> <Geometry>
>>> <PropertyName>Communities</PropertyName>
>>> </Geometry>
>>> I do not have that element at all. Mapserver documentation says that it
>>> is not supported and I also believe that now it is wrong in your SLD. I
>>> understand that your SLD is trying to telll now that the geometry of
>>> your layer is stored in a field named "Communities". By the way, it
>>> might be better to use different names in various places instead of
>>> "Communities" everywhere at least when testing.
>>> Geoserver folks have made a SLD cookbook
>>> http://docs.geoserver.org/stable/en/user/styling/sld-cookbook/index.html
>>> it is probably worth reading.
>>> And here is the SLD that I looked at when doing comparison. I took it
>>> out from my working Mapserver layer with GetStyles. Perhaps you could
>>> try the same, style your layer to look good by editing the mapfile and
>>> take the SLD out with GetStyles and you should have a good template in
>>> your hands.
>>> <NamedLayer>
>>> <Name>maxspeed_query</Name>
>>> <UserStyle>
>>> <FeatureTypeStyle>
>>> <Rule>
>>> <LineSymbolizer>
>>> <Stroke>
>>> <CssParameter name="stroke">#ff0000</CssParameter>
>>> <CssParameter name="stroke-opacity">1.00</CssParameter>
>>> <CssParameter name="stroke-width">3.00</CssParameter>
>>> </Stroke>
>>> </LineSymbolizer>
>>> </Rule>
>>> </FeatureTypeStyle>
>>> </UserStyle>
>>> </NamedLayer>
>>> </StyledLayerDescriptor>
>>> -Jukka Rahkonen-
>>> K wrote
>>>> As I am still unable to get my SLD to work, I wonder if the
>>>> shape file
>>>> (is it a shape file?) and map file for that example is available to
>>>> download somewhere? This way I can toss it on my server and
>>>> it would let
>>>> me see if my problem is software related, rather then something wrong
>>>> with my files.
>>>> Thanks,
>>>> Ken
>>>> On 18/10/2010 5:31 PM, Jeff McKenna wrote:
>>>>> On 10-10-18 11:16 AM, Rahkonen Jukka wrote:
>>>>>> I noticed that none of the full request links in the document
>>>>>> http://mapserver.org/ogc/sld.html are working now
>>>>> Good catch Jukka. The examples should be working again,
>>>> please re-try.
>>>>> -jeff
More information about the MapServer-users mailing list
